[GRASS-dev] Implement a REST API for GRASS
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Thu May 25 01:24:33 PDT 2017
Seen this: https://bitbucket.org/huhabla/open-graas?
Cheers
Stefan
________________________________________
Von: grass-dev [grass-dev-bounces at lists.osgeo.org] im Auftrag von Maris Nartiss [maris.gis at gmail.com]
Gesendet: Donnerstag, 25. Mai 2017 09:42
An: Pietro
Cc: GRASS developers list
Betreff: Re: [GRASS-dev] Implement a REST API for GRASS
I assume that both are equally dangerous. My opinion is that GRASS GIS
should not be exposed to any non trustable users, as various smaller
and larger bugs are too common. Unless, of course, it runs inside a
throw-away VM.
2017-05-25 10:33 GMT+03:00 Pietro <peter.zamb at gmail.com>:
> Dear Māris,
> On Wed, May 24, 2017 at 8:52 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> GRASS GIS code has never been developed with security in mind. I would
>> not suggest to run it in a non-trustable environment.
> Do you think that expose some GRASS modules through a REST API can be more
> dangerous than exposing the same modules through a WPS service? Why?
> Pietro
grass-dev mailing list
grass-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
