[GRASS-dev] segmentation fault with r.surf.idw -e
Anna Petrášová
kratochanna at gmail.com
Sat Nov 4 17:58:55 PDT 2017
On Sat, Nov 4, 2017 at 6:56 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hello devs,
> When running r.surf.idw with the e flag, I am getting a segmentation fault
> (core dumped).
> I am on Ubuntu 16.04 and I am using GRASS GIS from trunk
> So, if I run the following:
> g.mapset -c mapset=exercise
> g.region -p raster=elev_state_500m at PERMANENT
> v.to.rast input=precip_30ynormals at PERMANENT output=weatherstations use=attr
> attribute_column=annual
> r.mapcalc expression="rainfall_int = int(rainfallstations*10)"
> r.surf.idw -e input=rainfall_int output=cv_errormap
> Output is:
> Reading raster map <rainfall_int>...
> 100%
> Interpolating raster map <cv_errormap> (669 rows)...
> Segmentation fault (core dumped)
> [Raster MASK present]
> It works with a smaller region, but the region used in this example or the
> number of points isn't that big I would say? Am I doing something wrong or
> should I file a bug report?
it crashes on this line:
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_2/raster/r.surf.idw/main.c#L431
but I would need to dig into what the code is actually doing there.
Check whether there is already a ticket for this, but otherwise,
please create new one.
Anna
> Best wishes,
> Paulo
> Same but setting debug=3:
> GRASS 7.3.svn (nc_spm_08_grass7):~ > g.gisenv set="DEBUG=3"
> D1/3: G_set_program_name(): g.gisenv
> D3/3: G_option_to_separator(): key = separator -> sep = '/'
> GRASS 7.3.svn (nc_spm_08_grass7):~ > r.surf.idw -e input=rainfall_int
> output=cv_errormap
> D1/3: G_set_program_name(): r.surf.idw
> D2/3: G_file_name(): path =
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell/cv_errormap
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/WIND
> D2/3: file open: read (mode = r)
> D2/3: G__read_Cell_head
> D2/3: G__read_Cell_head_array
> D3/3: region item: proj: 99
> D3/3: region item: zone: 0
> D3/3: region item: north: 318500
> D3/3: region item: south: -16000
> D3/3: region item: east: 963000
> D3/3: region item: west: 124000
> D3/3: region item: cols: 1678
> D3/3: region item: rows: 669
> D3/3: region item: e-w resol: 500
> D3/3: region item: n-s resol: 500
> D3/3: region item: top: 1.000000000000000
> D3/3: region item: bottom: 0.000000000000000
> D3/3: region item: cols3: 1678
> D3/3: region item: rows3: 669
> D3/3: region item: depths: 1
> D3/3: region item: e-w resol3: 500
> D3/3: region item: n-s resol3: 500
> D3/3: region item: t-b resol: 1
> D1/3: G_find_raster(): name=MASK mapset=exercise
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell/MASK
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cellhd/MASK
> D3/3: region item: format: 0
> D3/3: region item: compressed: 2
> D1/3: G_find_raster2(): name=MASK mapset=exercise
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/fcell/MASK
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/g3dcell/MASK
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/MASK/gdal
> D3/3: create window mapping (1678 columns)
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/MASK/null
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/MASK/nullcmpr
> D1/3: G_find_raster2(): name=rainfall_int mapset=
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/SEARCH_PATH
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/PERMANENT
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/bioclim
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/landsat
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/modis_lst
> D2/3: G_file_name(): path = /home/paulo/Data/GRASSdb/nc_spm_08_grass7/user1
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cellhd/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/PERMANENT/cellhd/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/bioclim/cellhd/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/landsat/cellhd/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/modis_lst/cellhd/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/user1/cellhd/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell/rainfall_int
> D3/3: region item: format: 1
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/fcell/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/g3dcell/rainfall_int
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/rainfall_int/gdal
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/rainfall_int/null
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/cell_misc/rainfall_int/nullcmpr
> 100%
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/GDAL
> D2/3: G__temp_element(): .tmp/HP-Z600 (tmp=0)
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/.tmp/HP-Z600/5463.0
> D2/3: G_tempfile_pid():
> /home/paulo/Data/GRASSdb/nc_spm_08_grass7/exercise/.tmp/HP-Z600/5463.1
> GRASS 7.3.svn (nc_spm_08_grass7):~ > ^C
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
