[GRASS-dev] Does multi-threading apply to r.series.lwr?
Nikos Alexandris nik at nikosalexandris.net
Tue Nov 7 01:55:57 PST 2017
Nikos Alexandris wrote:
>> Before processing tens of thousands of Landsat8 TIRS bands, a script
>> tests the workflow described below, for 74 scenes, that correspond to one
>> WRS2 tile.
>> The script takes as inputs:
>> <Landsat8Pool> path to directory with Landsat scenes
>> <ScenePattern> regex pattern to match a set of Landsat scene identifiers
>> <LandCover> land cover map
>> <grassdb> path to the GRASS GIS data base
>> <Location> name for the GRASS GIS Location
>> <TargetMapset> name for the GRASS GIS Mapset to host maps to build a time
>series
>> <WindowSize> an odd integer, parameter for a split-window algorithm (SW)
>> Part 1 of the workflow derives Land Surface Temperature maps by:
>> 1. Creating the target Location
>> 2. Linking pseudo GRASS raster maps to Landsat8 GeoTIFF files
>> 3. Exporting a TGIS-compliant list of maps and timestamps
>> 4. Importing a land cover map required for the SW algorithm
>> 5. Estimating Land Surface Temperature (LST) maps for given scenes (i.landsat8.swlst)
>> 6. Creating a dedicated Mapset for LST maps
>> 7. Copying LST maps in the "LST" Mapset
>> 8. Removing initial LST maps from individual scene Mapsets
>> With a somewhat strong CPU, producing one LST map (7771 rows by 7651
>> columns = 59455921 cells), takes ~34 minutes.
>> For 74 Landsat8 input scenes, first trials took about 42 hours, running
>> grass-7.3.svn inside a docker container, albeit assigned one CPU.
>> Part 2 concerns building Time Series by:
>> 1. Creating and LST Spatio-Temporal Raster Dara Set (STRDS)
>> 2. Registering LST maps in TGIS' data base
>> 3. Smoothing the LST STRDS via Local Weighted Regression (r.series.lwr)
>> 4. Timestamping Local-Weight-Regression derived maps
>> 5. Creating an STRDS for LWR maps
>> 6. Registering LWR maps in TGIS' data base
>> Part 2 took about 130 minutes including all steps. Obviously, step 3 is
>> practically the consumer.
>> Overall it took about 44 hours to build an LWR Smoothed LST STRDS.
>> After proofing the concept, good use of the cluster concerns steps 2, 5,
>> 7 and 8 (of Part 1). Processes that can/should run in parallel, in an
>> (admittedly heterogeneous) cluster that consists of 912 cores.
>> Final concern is if multi-threading applies to r.series.lwr (step 3 of
>> Part 2).
Markus Metz <markus.metz.giswork at gmail.com> [2017-11-03 22:08:39 +0100]:
>You could
>1. create different temporal chunks of the time series, each chunk will be
>processed by r.series.lwr, all chunks can be processed in parallel.
>2. create different spatial chunks of the time series (tiling the
>computational region), each chunk will be processed by r.series.lwr, all
#2 is, sort of, obvious and not difficult to realise.
I am statistically puzzled about #1 in what concerns the degree of
over-determination (dod) and the maximum size of gaps to be interpolated
(maxgap) if the time series is temporally split.
I will proceed with #2 and set #1 aside as a future (study and learn) goal.
Much appreciated, it certainly helps,
N
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171107/6a570925/attachment.sig>
