[GRASS-dev] [GRASS GIS] #3435: r.terraflow tool memory error
GRASS GIS trac at osgeo.org
Wed Nov 8 22:59:01 PST 2017
  Reporter:  jess42  |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:
 Component:  Raster  |    Version:  7.2.2
Resolution:          |   Keywords:  r.terraflow
       CPU:  x86-64  |   Platform:  All
Changes (by martinl):
 * keywords:   => r.terraflow
 * component:  Default => Raster
Old description:
> When using 7.2.1 I tried to run the r.terraflow tool I received this
> message:
> r.terraflow elevation=waitunaDEM at PERMANENT filled=fill direction=flowdir
> swatershed=swatershed accumulation=accum tci=tciwaituna
> This application has requested the Runtime to terminate it
> in an unusual way.
> Please contact the application's support team for more
> information.
> Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
> STREAM temporary files in C:\Users\jessi\Documents\grassdata
> \Waituna\PERMANENT\.tmp/unknown\17040.0  (THESE INTERMEDIATE
> STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION
> OF THE PROGRAM. TO SAVE SPACE PLEASE DELETE THESE FILES
> MANUALLY!)
> total elements=1, nodata elements=1
> largest temporary files:
> FILL: 56 [1 elements, 56B each]
> FLOW: 0 [0 elements, 80B each]
> Will need at least 112 space available in
> C:\Users\jessi\Documents\grassdata\Waituna\PERMANENT\.tmp/unknown\17040.0
> Assertion failed!
> Program: C:\PROGRA~1\QGIS2~1.18\apps\grass\grass-7.2.1\bin\r
> .terraflow.exe
> File: 3scan.h, Line 79
> Expression: ae == AMI_ERROR_NO_ERROR
> (Thu Nov 09 08:45:31 2017) Command finished (7 sec)
> When using 7.2.2 I tried to run the r.terraflow tool I received this
> message:
> (Mon Nov 06 16:32:04 2017)
> r.terraflow elevation=waitunaDEM at PERMANENT filled=filled
> direction=flowdir swatershed=swatershed accumulation=accum tci=tci
> in an unusual way.
> information.
> (Mon Nov 06 16:32:33 2017) Command finished (29 sec)
> I have uninstalled and reinstalled the latest version of the software but
> I still cannot get this tool to work. 7.2.1 and 7.2.2 were tested on two
> different computers that have a large amount of space and RAM.
New description:
 message:
 in an unusual way.
 information.
 MANUALLY!)
 Assertion failed!
 .terraflow.exe
 message:
 r.terraflow elevation=waitunaDEM at PERMANENT filled=filled direction=flowdir
 in an unusual way.
 information.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3435#comment:1>
