[GRASS-dev] Different CRS matching in 7.2 and trunk
Vaclav Petras wenzeslaus at gmail.com
Fri Nov 10 09:08:28 PST 2017
Hi all,
I'm trying to understand a change of behavior between 7.2 and trunk. With
7.2, I can do the following:
curl -SL http://fatra.cnr.ncsu.edu/foss4g2017/nc_tile_0793_016_spm.zip \
    > nc_tile_0793_016_spm.zip  && unzip nc_tile_0793_016_spm.zip
grass72 -c EPSG:3358 ~/grassdata/crs_test -e
grass72 ~/grassdata/crs_test2/PERMANENT/ --exec r.in.lidar
input=nc_tile_0793_016_spm.las output=count_10 method=n -e -n resolution=10
The last step (r.in.lidar) fails in current trunk because the projection
don't match. Here is the difference (name, datum and swapped lat_1 and
lat_2):
       GRASS LOCATION PROJ_INFO is:
       name: NAD83(HARN) / North Carolina
       datum: nad83harn
       lat_1: 36.16666666666666
       lat_2: 34.33333333333334
       Import dataset PROJ_INFO is:
       datum: nad83
       lat_1: 34.33333333333334
       lat_2: 36.16666666666666
7.2 considers this OK while trunk considers this different. I'm not sure
which one is correct.
Here is the lasinfo reference:
PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200",
    GEOGCS["GCS_North_American_1983",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS_1980",6378137,298.257222101]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.0174532925199432955]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["False_Easting",609601.22],
    PARAMETER["False_Northing",0],
    PARAMETER["Central_Meridian",-79],
    PARAMETER["Standard_Parallel_1",34.33333333333334],
    PARAMETER["Standard_Parallel_2",36.16666666666666],
    PARAMETER["Latitude_Of_Origin",33.75],
    UNIT["Meter",1]]
`r.in.lidar -p` in both 7.2 and trunk gives:
+proj=lcc +lat_1=34.33333333333334 +lat_2=36.16666666666666 +lat_0=33.75
+lon_0=-79 +x_0=609601.22 +y_0=0 +datum=NAD83 +units=m +no_defs
`g.proj -p` gives the following in 7.2 and trunk in locations created by
7.2 and trunk:
-PROJ_INFO-------------------------------------------------
name       : NAD83(HARN) / North Carolina
datum      : nad83harn
ellps      : grs80
proj       : lcc
lat_1      : 36.16666666666666
lat_2      : 34.33333333333334
lat_0      : 33.75
lon_0      : -79
x_0        : 609601.22
y_0        : 0
no_defs    : defined
-PROJ_EPSG-------------------------------------------------
epsg       : 3358
-PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1
I don't know how to resolve it besides using -o but I don't know how to
justify it and why there is a difference (I don't see it in the recent
proj-related commits).
Thank you,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171110/c5fe5f3a/attachment.html>
