[GRASS-dev] [release planning] 7.4.0
Moritz Lennert mlennert at club.worldonline.be
Fri Nov 10 09:39:25 PST 2017
Hi Maris,
Le Sun, 29 Oct 2017 12:31:35 +0200,
Maris Nartiss <maris.gis at gmail.com> a écrit :
> I added simple tests for v.profile. [1]
> I also changed one of examples from documentation to use NC Basic
> dataset. [2]
> If v.profile is moved to trunk, README file should be deleted.
> As there seem to be a lot of +1's and the requirement of tests is
> fulfilled, this addon should be moved to trunk to gain some exposure
> before release (or wait till 7.4.1).
v.profile still uses the old buffering library methods which has quite
a lot of issues.
As an example, I attach the output map of the following example:
v.profile input=geonames_NC at PERMANENT output=- separator=comma dp=3
buffer=500 profile_map=roadsmajor at PERMANENT profile_where=cat=193
map_output=test_profile
I also attach the equivalent v.buffer output:
v.buffer -c roadsmajor where=cat=193 dist=500 out=buff500
Would it be possible for you, Maris, to change to the GEOS method used
in v.buffer in order to get the same buffering output ?
This is not only formal as you can see when you use the following
vector points as input:
v.in.ascii in=- out=test_points << EOF
626382.68026139|228917.44816672|1
626643.91393428|228738.2879083|2
626907.14939778|228529.10079092|3
EOF
v.profile then misses out on point 2, even though it is within 500m:
v.profile input=test_points output=- separator=comma dp=3 buffer=500
Number,Distance,cat,dbl_1,dbl_2,int_1
1,2102.114,3,626907.14939778,228529.10079092,3
2,2960.822,1,626382.68026139,228917.44816672,1
Moritz
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171110/031ac8ef/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171110/031ac8ef/attachment-0003.png>
