[GRASS-dev] [GRASS GIS] #3430: v.clean threshold in lat-long: metric or not?
trac at osgeo.org
Fri Nov 10 11:31:08 PST 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Vector | Version: 7.2.2
Resolution: | Keywords: v.clean
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:1 mlennert]:
> Replying to [ticket:3430 neteler]:
> > Should the G_important_message() be removed from main.c?
> Looking through the code, I actually have the feeling that the
documentation is wrong, at least for some of v.clean's functionalities.
> So while area calculations might use meters (i.e. the rmarea function
mentioned in the SE message), I'm not sure this is the case for snapping
distances... I think this needs very careful review before deciding what
to do.
I suggest to remove the message, because the message does not distinguish
between the different cleaning tools. For tool=rmarea, the threshold must
always be in square meters as stated in the manual. Otherwise, I'm pretty
sure that the threshold is map units, also for latlon.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3430#comment:2>
