[GRASS-dev] [release planning] 7.4.0
Nikos Alexandris
nik at nikosalexandris.net
Fri Nov 10 15:42:24 PST 2017
* Veronica Andreo <veroandreo at gmail.com> [2017-09-11 18:54:00 +0200]:
>Hi all :)
>2017-09-02 17:57 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
>> On Fri, Sep 1, 2017 at 9:56 PM, Martin Landa <landa.martin at gmail.com>
>> wrote:
>> > Please all devs try to remember all cool features you implemented for
>> > G74 and put notes about that on trac wiki page! It will help a lot
>> > (going through all logs and discover new features is a very hard and
>> > time consuming job).
>> Some help for this:
>> * 24 May 2016 Creation of the GRASS GIS 7.2 release branch (r68500)
>> To save you some time, I have diff'ed the 7.2.2svn and 7.4.svn
>there's no 7.4.svn yet, right? Only trunk (grass73), no?
>Changelogs and removed from the result obvious "trivial" changes. The
>> remainder is here:
>> https://data.neteler.org/tmp/ChangeLog74_filtered.txt
>> From browsing this file memories may come back :-)
>> Please add findings then to
>> https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures74
>I started going through the document to add what I believe might be
>relevant stuff to the NewFeatures74 page, but some things in that diff file
>were already reported in NewFeatures72, eg: all d.* changes done by Adam
>Laza in GSoC 2016... so, I'm (will be) double checking. I wonder however if
>it is ok to diff against r68500 or should be a later version (eg.: the
>stable version released in December 2016, for example)? No idea
>> (also screenshots would be great)
>yes! As well as some extra description from devs for the new cool features
>implemented or examples of use of new features (or important bug fixes)!
>That would make it much easier to then write the announcements, promote
>grass elsewhere and show off a bit ;-)
>cheers,
>Vero
Last 100+ lines of https://data.neteler.org/tmp/ChangeLog74_filtered.txt
checked. Majority of entries already included in
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures72 and/or
https://trac.osgeo.org/grass/log/grass/branches/releasebranch_7_2/.
Few entries added in
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures74.
Diff file between ChangeLog74_filtered.txt any my review attached.
Nikos
* raster/r.lake/main.c: r.lake: more guisections * raster/r.lake/main.c: r.lake: more guisections
* gui/wxpython/gmodeler/model.py: g.gui.gmodeler: substitute | [Exclude] * gui/wxpython/gmodeler/model.py: g.gui.gmodeler: s
* vector/v.outlier/main.c: v.outlier: define parser rule for | [Exclude] * vector/v.outlier/main.c: v.outlier: define parser
* include/iostream/mm.h, lib/iostream/mm.cpp: use exception | [Exclude] * include/iostream/mm.h, lib/iostream/mm.cpp: use e
* raster/r.terraflow/grass2str.h: r.terraflow: add space bet | [Exclude] * raster/r.terraflow/grass2str.h: r.terraflow: add
* lib/init/helptext.html: helptext.html: improved section ab | [Exclude] * lib/init/helptext.html: helptext.html: improved s
* lib/init/helptext.html: helptext.html: add section about t | [Exclude] * lib/init/helptext.html: helptext.html: add sectio
* lib/init/grass.py: init: fix typo in r68797; advise user a | [Exclude] * lib/init/grass.py: init: fix typo in r68797; advi
* raster/r.topidx/r.topidx.html: r.topidx: Fixed a link | [Exclude] * raster/r.topidx/r.topidx.html: r.topidx: Fixed a
* raster/r.topmodel/r.topmodel.html: r.topmodel: Fixed a lin | [Exclude] * raster/r.topmodel/r.topmodel.html: r.topmodel: Fi
* lib/init/grass.py: init: advise user about --help and -c | [Exclude] * lib/init/grass.py: init: advise user about --help
* gui/wxpython/gui_core/gselect.py, gui/wxpython/modules/imp | [Exclude] * gui/wxpython/gui_core/gselect.py, gui/wxpython/mo
* vector/v.overlay/main.c: v.overlay: avoid fatal error (lay | [Exclude] * vector/v.overlay/main.c: v.overlay: avoid fatal e
* display/d.legend/d.legend.html: d.legend: typo in document | [Exclude] * display/d.legend/d.legend.html: d.legend: typo in
* display/d.legend/d.legend.html, display/d.legend/d_legend_ | [Exclude] * display/d.legend/d.legend.html, display/d.legend/
* display/d.legend/draw.c, display/d.legend/main.c: d.legend | [Exclude] * display/d.legend/draw.c, display/d.legend/main.c:
* gui/wxpython/gui_core/dialogs.py, gui/wxpython/gui_core/fo | [Include][Font can be selected interactively in module dialog
* lib/gis/colors.desc, lib/gis/colors/grass: add GRASS green | [Exclude] * lib/gis/colors.desc, lib/gis/colors/grass: add GR
* gui/wxpython/gui_core/forms.py: wxGUI: fix escape button t | [Exclude] * gui/wxpython/gui_core/forms.py: wxGUI: fix escape
* display/d.legend/draw.c, display/d.legend/local_proto.h, d | [???????] * display/d.legend/draw.c, display/d.legend/local_p
* raster/r.info/main.c: r.info: make category title the prim | [Exclude] * raster/r.info/main.c: r.info: make category title
* raster/r.support/main.c: r.support: remove unused variable | [Exclude] * raster/r.support/main.c: r.support: remove unused
* raster/r.support/main.c: r.support: write category title, | [Exclude] * raster/r.support/main.c: r.support: write categor
* raster/r.to.vect/main.c: r.to.vect: fix r68720, support -v | [Exclude] * raster/r.to.vect/main.c: r.to.vect: fix r68720, s
* raster/r.param.scale/r.param.scale.html: Update link in r. | [Exclude] * raster/r.param.scale/r.param.scale.html: Update l
* lib/python/script/raster3d.py: pythonlib: apply r60662 (st | [Exclude][???????] * lib/python/script/raster3d.py: pythonlib
* raster/r.to.vect/main.c: r.to.vect: -v and -b flags are mu | [Exclude] * raster/r.to.vect/main.c: r.to.vect: -v and -b fla
* lib/python/pygrass/vector/__init__.py, lib/python/pygrass/ | [Exclude][???????] * lib/python/pygrass/vector/__init__.py, l
* raster/r.mapcalc/map.c: Fix #3067 | [Exclude][???????] * raster/r.mapcalc/map.c: Fix #3067
* raster/r.to.vect/areas.c, raster/r.to.vect/areas_io.c, ras |
* gui/wxpython/gui_core/preferences.py: wxGUI: draw example | [Exclude][Source code is the same in 7.4 and 7.2] * raster/r.
* raster3d/r3.in.ascii/main.c: r3.in.ascii: use stdin code f |
* display/d.text/main.c: d.text: reorganize options in gui, | [Exclude] * gui/wxpython/gui_core/preferences.py: wxGUI: draw
* raster/r.mapcalc/testsuite/test_row_above_below_bug.py: r. | [Exclude] * raster3d/r3.in.ascii/main.c: r3.in.ascii: use std
* gui/wxpython/core/utils.py, gui/wxpython/gis_set.py: wxGUI | [Exclude] * display/d.text/main.c: d.text: reorganize options
* gui/wxpython/core/render.py: wxGUI: fix passing non ascii | [Exclude] * raster/r.mapcalc/testsuite/test_row_above_below_b
* lib/python/script/task.py: wxGUI: fix passing non ascii ch | [???????] * gui/wxpython/core/utils.py, gui/wxpython/gis_set.
* display/d.legend/draw.c, display/d.legend/get_stats.c, dis | [???????] * gui/wxpython/core/render.py: wxGUI: fix passing n
* display/d.legend/draw.c, display/d.legend/histogram.c, dis | [???????] * lib/python/script/task.py: wxGUI: fix passing non
* imagery/i.vi/main.c: i.vi: apply standard NDVI color table | [Exclude] * display/d.legend/draw.c, display/d.legend/get_sta
* imagery/i.vi/main.c: i.vi: writing of color table fixed | [Exclude][Already included in https://trac.osgeo.org/grass/wi
* raster/r.patch/main.c, raster/r.patch/r.patch.html: r.patc | [???????] * imagery/i.vi/main.c: i.vi: apply standard NDVI co
* display/d.legend/main.c: d.legend: improvements by Adam La | [Exclude] * imagery/i.vi/main.c: i.vi: writing of color table
* gui/wxpython/lmgr/frame.py, gui/wxpython/lmgr/layertree.py | [Exclude][Already included in <https://trac.osgeo.org/grass/l
* CITING, Makefile: g.version: improved citation text; added | [Exclude][Already included in https://trac.osgeo.org/grass/wi
* gui/wxpython/gui_core/ghelp.py: wxGUI: use TextCtrl in Abo | [Exclude] * gui/wxpython/lmgr/frame.py, gui/wxpython/lmgr/lay
* gui/wxpython/gui_core/ghelp.py: wxGUI: add g.version citat | [Exclude][See older "CITING" commit message] * CITING, Makefi
* general/g.version/main.c, lib/init/grass.py: g.version + s | [Exclude] * gui/wxpython/gui_core/ghelp.py: wxGUI: use TextCt
* CITING, general/g.version/Makefile, general/g.version/main | [Exclude][Merge With "CITING" below!][Already included in <ht
* .travis.yml: travis CI: add Notifications from travis (con | [Exclude] * general/g.version/main.c, lib/init/grass.py: g.ve
* lib/proj/Makefile: libproj: Makefile updated for new ntf_r | [Exclude][Already included in <https://trac.osgeo.org/grass/b
* lib/proj/ntf_r93.gsb, lib/proj/null.lla: libproj: added nt | [Exclude] * .travis.yml: travis CI: add Notifications from tr
* mswindows/osgeo4w/package.sh: wingrass: disable mysql supp | [Exclude] * lib/proj/Makefile: libproj: Makefile updated for
* .gitignore, .travis, .travis.yml, .travis/.travis.linux.be | [Icluded][Included as part of "improved integration of GDAL a
* gui/wxpython/nviz/mapwindow.py: wxGUI/nviz: when showing l | [Exclude] * mswindows/osgeo4w/package.sh: wingrass: disable m
* gui/wxpython/lmgr/frame.py: wxGUI: fix loading workspace a | [Exclude] * .gitignore, .travis, .travis.yml, .travis/.travis
* gui/wxpython/core/workspace.py, gui/wxpython/lmgr/frame.py | [Exclude] * gui/wxpython/nviz/mapwindow.py: wxGUI/nviz: when
* imagery/i.atcorr/geomcond.cpp, imagery/i.atcorr/geomcond.h | [Exclude] * gui/wxpython/lmgr/frame.py: wxGUI: fix loading wo
* mswindows/osgeo4w/package.sh: wingrass: enable mysql suppo | [Exclude] * gui/wxpython/core/workspace.py, gui/wxpython/lmgr
* mswindows/osgeo4w/mysql_config: wingrass: add mysql_config | [Exclude][Already included in <https://trac.osgeo.org/grass/b
* gui/wxpython/lmgr/frame.py: wxGUI: add north arrow the sam | [Exclude][Newer Commit Message Above] * mswindows/osgeo4w/pac
* raster/r.grow.distance/main.c: r.grow.distance: just leave | [Exclude] * mswindows/osgeo4w/mysql_config: wingrass: add mys
* mswindows/Makefile: partly revert r68605 | [Exclude] * gui/wxpython/lmgr/frame.py: wxGUI: add north arro
* mswindows/Makefile, mswindows/osgeo4w, mswindows/osgeo4w/M | [Exclude] * raster/r.grow.distance/main.c: r.grow.distance: j
* lib/python/docs/src/pygrass_vector.rst: pygrass: update do | [Exclude] * mswindows/Makefile: partly revert r68605
* scripts/r3.in.xyz/r3.in.xyz.py: r3.in.xyz: unify keywords | [Exclude] * mswindows/Makefile, mswindows/osgeo4w, mswindows/
* raster3d/r3.in.lidar/main.c: r3.in.lidar: unify keywords a | [Exclude] * lib/python/docs/src/pygrass_vector.rst: pygrass:
* raster/r.in.xyz/main.c: r.in.xyz: unify keywords and metho | [Exclude] * scripts/r3.in.xyz/r3.in.xyz.py: r3.in.xyz: unify
* lib/gis/parser_standard_options.c: parser: unify SQL param | [Exclude] * raster3d/r3.in.lidar/main.c: r3.in.lidar: unify k
* vector/v.in.lidar/v.in.lidar.html: v.in.lidar: use smaller | [Exclude] * raster/r.in.xyz/main.c: r.in.xyz: unify keywords
* man/grassdocs.css: docs: CSS style for compact table and d | [Exclude] * lib/gis/parser_standard_options.c: parser: unify
* raster/r.in.lidar/main.c, raster/r.in.lidar/r.in.lidar.htm | [Exclude] * vector/v.in.lidar/v.in.lidar.html: v.in.lidar: us
* mswindows/osgeo4w/mklibs.sh: wingrass: update for VC 2015 | [Exclude] * man/grassdocs.css: docs: CSS style for compact ta
* include/gis.h, lib/raster/color_read.c, lib/raster3d/color | [Exclude][Already included in <https://trac.osgeo.org/grass/l
* imagery/i.eb.eta/eta.c, imagery/i.evapo.pt/pt_daily_et.c: | [Exclude] * mswindows/osgeo4w/mklibs.sh: wingrass: update for
* imagery/i.evapo.mh/mh_eto.c, imagery/i.evapo.mh/mh_origina | [???????] * include/gis.h, lib/raster/color_read.c, lib/raste
* display/d.barscale/draw_scale.c, display/d.barscale/main.c | [Exclude] * imagery/i.eb.eta/eta.c, imagery/i.evapo.pt/pt_dai
* imagery/i.evapo.mh/mh_eto.c, imagery/i.evapo.mh/mh_origina | [Exclude] * imagery/i.evapo.mh/mh_eto.c, imagery/i.evapo.mh/m
* lib/raster/raster.c: rasterlib: docs for Rast_raster_cpy f | [Exclude][Already included, likely, in <https://trac.osgeo.or
* gui/wxpython/xml/menudata_pyedit.xml: wxGUI/pyedit: improv | [Exclude] * imagery/i.evapo.mh/mh_eto.c, imagery/i.evapo.mh/m
* general/g.message/g.message.html, lib/init/grass.py: repla | [Exclude] * lib/raster/raster.c: rasterlib: docs for Rast_ras
* raster/r.slope.aspect/testsuite/test_r_slope_aspect.py: r. | [Exclude] * gui/wxpython/xml/menudata_pyedit.xml: wxGUI/pyedi
* display/d.grid/plot.c: d.grid: fix labels in latlon, see # | [Exclude] * general/g.message/g.message.html, lib/init/grass.
* imagery/i.segment/create_isegs.c: i.segment: fix manhattan | [Exclude] * raster/r.slope.aspect/testsuite/test_r_slope_aspe
* display/d.grid/plot.c: d.grid: draw labels background over | [???????] * display/d.grid/plot.c: d.grid: fix labels in latl
* lib/python/script/setup.py: pythonlib: fix import in examp | [Exclude][Already included in <https://trac.osgeo.org/grass/b
* lib/gis/parser_html.c: parser: space between thumbnail and | [Exclude] * display/d.grid/plot.c: d.grid: draw labels backgr
* gui/wxpython/gui_core/preferences.py: wxGUI: remove condit | [Exclude] * lib/python/script/setup.py: pythonlib: fix import
* raster/r.clump/clump.c, raster/r.clump/local_proto.h, rast | [Exclude] * lib/gis/parser_html.c: parser: space between thum
* display/d.grid/d.grid.html, display/d.grid/local_proto.h, | [Exclude] * gui/wxpython/gui_core/preferences.py: wxGUI: remo
* mswindows/Makefile: fix wingrass: update setup.hint by bui | [Exclude][Included already in <https://trac.osgeo.org/grass/w
* mswindows/Makefile, mswindows/osgeo4w/Makefile, mswindows/ | [Exclude][Already included in <https://trac.osgeo.org/grass/w
* gui/wxpython/gui_core/preferences.py: wxGUI: use custom fo | [Exclude] * mswindows/Makefile: fix wingrass: update setup.hi
* gui/wxpython/gui_core/preferences.py: wxGUI: fix opening d | [Exclude] * mswindows/Makefile, mswindows/osgeo4w/Makefile, m
* display/d.northarrow/main.c: d.northarrow: fix multiplicat | [Exclude] * gui/wxpython/gui_core/preferences.py: wxGUI: use
* display/d.grid/fiducial.c, display/d.grid/local_proto.h, d | [Exclude] * gui/wxpython/gui_core/preferences.py: wxGUI: fix
* display/d.barscale/draw_scale.c, display/d.barscale/main.c | [Exclude] * display/d.northarrow/main.c: d.northarrow: fix mu
* display/d.northarrow/d.northarrow.html: d.northarrow: impr | [Exclude] * display/d.grid/fiducial.c, display/d.grid/local_p
* lib/gis/colors.desc, lib/gis/colors/viridis: add viridis c | [Exclude] * display/d.barscale/draw_scale.c, display/d.barsca
* gui/wxpython/gui_core/widgets.py: wxGUI: fix 4pt_star pict | [Exclude] * display/d.northarrow/d.northarrow.html: d.northar
* gui/wxpython/gui_core/widgets.py: wxGUI: show d.northarrow | [???????] * lib/gis/colors.desc, lib/gis/colors/viridis: add
* include/VERSION: update VERSION file after 7.2.svn release | [Exclude] * gui/wxpython/gui_core/widgets.py: wxGUI: fix 4pt_
> [???????] * gui/wxpython/gui_core/widgets.py: wxGUI: show d.n
> [Exclude] * include/VERSION: update VERSION file after 7.2.sv
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171111/bff2f441/attachment-0001.sig>
