[GRASS-dev] winGRASS not built/broken
Markus Metz
markus.metz.giswork at gmail.com
Sat Nov 11 10:35:19 PST 2017
On Sat, Nov 11, 2017 at 6:01 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On samedi 11 novembre 2017 17:44:18 CET Markus Metz wrote:
> > On Sat, Nov 11, 2017 at 4:25 PM, Helmut Kudrnovsky <hellik at web.de>
wrote:
> > > it seems there is an issue with winGRASS:
> > > 32 bit:
> > > https://wingrass.fsv.cvut.cz/grass73/x86/logs/log-r71641-1/error.log
> > > GRASS GIS 7.3.svn r71641 compilation log
> > > Started compilation: Tue Nov 7 21:30:33 2017
> > > Errors in:
> > > /c/msys32/usr/src/grass_trunk/raster/r.in.gdal
> > The error is:
> > main.c:345: undefined reference to `GDALSetCacheMax64 at 4'
> > strange, GDALSetCacheMax64 should exist on 32 bit Windows, even if "the
> > maximum amount of memory that can be addressed by a process might be 2
GB
> > or 3 GB, depending on the operating system capabilities."
> > Falling back to GDALSetCacheMax for MS Windows (including 64 bit
Windows)
> > in r71677.
> The issue is probably that this build uses GDAL from OSGeo4W, into which
GDAL has been configured and compiled with MSVC. Thus HAVE_LONG_LONG is not
defined in cpl_config.h, and the GDALSetCacheMax64( GIntBig ) must evaluate
to GDALSetCacheMax64 ( int ) when including from GRASS. I guess defining
HAVE_LONG_LONG would solve the issue .
If GDALSetCacheMax64 must evaluate to GDALSetCacheMax64 ( int ), we can
just as well use GDALSetCacheMax( int), the argument is the same ( int ).
Markus M
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171111/127247df/attachment.html>
