[GRASS-dev] [GRASS GIS] #3421: GEOS C API usage
trac at osgeo.org
Sun Nov 12 03:53:31 PST 2017
Reporter: Bas Couwenberg | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Default | Version: 7.2.2
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by mmetz):
Replying to [comment:1 mmetz]:
> Replying to [ticket:3421 Bas Couwenberg]:
> > GRASS is claimed to be using the GEOS C API instead of the unstable
C++ API according to:
> > https://trac.osgeo.org/geos/wiki/Applications
> > `configure.in` checks for `geos_c.h`, but uses `geos-config --libs`
instead of `geos-config --clibs` causing linking to `libgeos-<VERSION>.so`
in addition to `libgeos_c.so`.
> > The attached patch updates the `geos-config` command to use `--clibs`.
> Thanks for the patch! Applied to trunk and relbr72 in r71544,5.
I guess the patch provided by you is working for you and it has been
applied to trunk and relbr72. Closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3421#comment:2>
