[GRASS-dev] winGRASS not built/broken
Helmut Kudrnovsky
hellik at web.de
Sun Nov 12 07:02:54 PST 2017
Helmut Kudrnovsky wrote
> it seems there is an issue with winGRASS:
> 32 bit:
> https://wingrass.fsv.cvut.cz/grass73/x86/logs/log-r71641-1/error.log
> GRASS GIS 7.3.svn r71641 compilation log
> Started compilation: Tue Nov 7 21:30:33 2017
> Errors in:
> /c/msys32/usr/src/grass_trunk/raster/r.in.gdal
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Tue Nov 7 22:05:34 2017
> 64bit:
> last build:
> WinGRASS-7.3.svn-r71641-404-Setup-x86_64.exe 08-Nov-2017 07:46 73M
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-dev
quick look into the log shows, the last compilation of binaries was still at
08-Nov-2017.
maybe there are other issues on the build server beside the ones found
yesterday?
best regards
Helmut
