[GRASS-dev] winGRASS not built/broken
Markus Metz
markus.metz.giswork at gmail.com
Mon Nov 13 13:30:48 PST 2017
On Sun, Nov 12, 2017 at 12:13 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On dimanche 12 novembre 2017 00:07:49 CET Markus Metz wrote:
> > Stupid question: such a #define has only effect on compile time. If GDAL
> > has been compiled without HAVE_LONG_LONG being defined, and then we
define
> > HAVE_LONG_LONG when compiling against GDAL, is this creating a big mess?
> With MSVC, GIntBig expands to __int64 , which is equivalent in practice
to long long.
MinGW also has __int64, therefore it would be great if you could apply
Index: port/cpl_port.h
--- port/cpl_port.h (revision 40701)
+++ port/cpl_port.h (working copy)
@@ -219,7 +219,7 @@
/* 64bit support */
-#if defined(WIN32) && defined(_MSC_VER)
+#if (defined(WIN32) && defined(_MSC_VER)) || defined(_WIN32)
#define VSI_LARGE_API_SUPPORTED
typedef __int64 GIntBig;
to gdal-trunk
Apart from that, GDALSetCacheMax[64](bytes) could be replaced with
CPLSetConfigOption( "GDAL_CACHEMAX", "MB" ), that should avoid the issues
with GIntBig on MS Windows.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171113/67cda3bb/attachment.html>
