[GRASS-dev] [GRASS GIS] #3442: Able to select unitis in r.volume
GRASS GIS trac at osgeo.org
Tue Nov 14 01:57:59 PST 2017
 Reporter:  malicera     |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  normal       |  Milestone:
Component:  Default      |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 The module r.volume is a very powerfull tool, but the lack of control over
 the units it produces its result and the lack of support of lon-lat units
 limits its use.
 I would like to have a way to indicate the units of the raster so the
 program can use an apropiate unit to calculate the area to match the sum,
 just as it is done when a surface calculation is required in the r.report.
 I have an example where some volumes were calculated that would be nice to
 do able to do with r.volume
 https://gis.stackexchange.com/questions/258482/how-to-restore-a-scarp-
 surface-grid-to-calculate-material-loss/259451#259451
Ticket URL: <https://trac.osgeo.org/grass/ticket/3442>
