[GRASS-dev] winGRASS not built/broken
    Even Rouault
    even.rouault at spatialys.com
    Tue Nov 14 11:26:36 PST 2017
On mardi 14 novembre 2017 19:56:25 CET Markus Metz wrote:
> On Tue, Nov 14, 2017 at 3:13 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > > Index: port/cpl_port.h
> > > --- port/cpl_port.h (revision 40701)
> > > +++ port/cpl_port.h (working copy)
> > > @@ -219,7 +219,7 @@
> > > /* 64bit support */
> > > -#if defined(WIN32) && defined(_MSC_VER)
> > > +#if defined(WIN32) && (defined(_MSC_VER) || defined(__MINGW32__))
> > > #define VSI_LARGE_API_SUPPORTED
> > > typedef __int64 GIntBig;
> > > to account for different compile environments on Windows that have
> __int64
> > Didn't know that mingw had __int64 as wel.
> According to the documentation, yes. I tested, and __int64 is indeed
> available with MinGW.
> > Could you submit that as a pull request against
> https://github.com/OSGeo/gdal so we can check that this doesn't break our 2
> mingw targets at
> > https://travis-ci.org/OSGeo/gdal ?
> Done:
> https://github.com/OSGeo/gdal/pull/262
> Regarding integer types with MSC: why is HAVE_LONG_LONG not defined in
> cpl_config.h for WIN32? There is a long long in WIN32 (equivalent to
> __int64).
I guess this dates back to ancient times, like Visual Studio C++ 6.0, where long long wasn't
available, but we no longer support that compiler. Apparently long long is available since VS
2005
I'm probably going to simplify things and have one single case for #if defined(WIN32) ||
defined(HAVE_LONG_LONG)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171114/7d27d582/attachment.html>
