[GRASS-dev] [GRASS GIS] #3444: v.concave.hull -script type definition for table column not compatible with PostgreSQL
trac at osgeo.org
Thu Nov 16 01:45:27 PST 2017
PostgreSQL
Reporter: harrik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: 7.2.0
Keywords: v.concave.hull, PostgreSQL | CPU: Unspecified
Platform: Unspecified |
Very simple. The GRASS Addon 'v.concave.hull' has a column definition that
does not work with the PostgreSQL backend:
Line 98:
grass.run_command('v.db.addtable', map = out_lines,
col = 'cat integer,length double', quiet = True)
That gives an error, whereas the simple replacement of `length double`
with `length double precision` makes the script run:
col = 'cat integer,length double precision', quiet =
True)
This should run at least with the sql-based backends since based on MySQL
and SQLite documentation the `double precision` is the full type name
anyway, but I do not know about DBF. But from what I've understood, the
use of DBF is not recommended any more anyway.
I could easily fix this myself, but I do not have write access to sources.
Harri
Ticket URL: <https://trac.osgeo.org/grass/ticket/3444>
