[GRASS-dev] r.mask: odd behavior?
    Markus Metz
    markus.metz.giswork at gmail.com
    Sun Nov 19 12:23:04 PST 2017
On Sun, Nov 19, 2017 at 9:19 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi devs,
> I found that r.mask does not behave as I would expect and I would really
appreciate some clarification.
> The issue is the following: I apply a mask, then I do some processing, I
remove the mask and when I display the resulting map, all the pixels were
processed. I would expect that those pixels that I masked were treated as
NULL and not considered exactly as the message says:
> "All subsequent raster operations will be limited to the MASK area.
Removing
> or renaming raster map named 'MASK' will restore raster operations to
> normal."
A MASK affects only reading raster data, not writing raster data. Therefore
r.mapcalc "test = 1" will always produce a map without NULL cells.
Markus M
> Otherwise, what's the point of applying a mask?
> This is an example with NC:
> g.region raster=landcover_1m -p
> r.category landcover_1m
> r.mask raster=landcover_1m maskcats="1 thru 6"
> d.mon wx0
> d.rast landcover_1m
> r.mapcalc "applied_mask = 1"
> r.mask -r
> d.erase
> d.rast applied_mask <<-- everything is there, no holes...
> The only operation that gave me what I would expect when I apply a mask
was:
> r.mapcalc expression="applied_mask=1-MASK"
> Can someone, please, test/clarify this?
> thanks much in advance!
> Vero
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171119/0066b5c6/attachment.html>
