[GRASS-dev] [GRASS GIS] #3451: module GUIs: selected subgroup not taken into account in created command line
trac at osgeo.org
Mon Nov 20 21:31:28 PST 2017
line
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
Steps to reproduce:
* create two image groups with identically named subgroups (i.e. subgroup
== all);
* in i.maxlik select group, subgroup, signature file;
* change group to the second one. As subgroup name is valid, there is
valid value in subgroup selection and it is possible to select correct
signature file, but subgroup parameter is missing in the resulting
command.
Workaround is to delete subgroup field contents and then select again the
same value from list.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3451>
