[GRASS-dev] Failed to create Windows Grass Installer
Markus Neteler
neteler at osgeo.org
Tue Nov 21 08:13:07 PST 2017
On Tue, Nov 21, 2017 at 4:55 PM, CM Reddy <chalamcharla at hotmail.com> wrote:
> Hi All,
> We had failed to create Grass Windows Installer from grass source of release
> build (version 7.2.0). We took help from the Compiling Grass on MS Windows
> link. We had successfully compiled the code on Windows and tested. Then, we
> tried to create the Windows Grass Installer using the steps specified in the
> above link. However, we stuck in the last step, i.e compiling
> Grass-Installer-nsi file.
> Steps followed to create Windows installer after testing the compiled Grass
> code.
> Copied the "mswindows" directory contents to "temp" directory in C drive
> Created the Grass self-contained package by running the Grass-Packager.bat
> Installed NSIS into C:\DevTools
> Installed Untgz plugin.
> Install AccessControl plugin.
> Compiled the Grass-Installer.nsi.
> Failed the "Grass-Installer.nsi" compilation with the following error.
> <NSIS error>
> Processed 1 file, writing output:
> Adding plug-ins initializing function... Done!
> Processing pages... Done!
> Removing unused resources... Done!
> Generating language tables... Done!
> Generating uninstaller... Internal compiler error #12345: deflateInit()
> failed(initialization failed [-2]).
> Note: you may have one or two (large) stale temporary file(s)
> left in your temporary directory (Generally this only happens on Windows
> 9x).
> </NSIS error>
Maybe the disk or RAM are full?
Markus
