[GRASS-dev] [GRASS GIS] #26: please let people find their EPSG on the web
GRASS GIS trac at osgeo.org
Sat Nov 25 13:08:12 PST 2017
  Reporter:  timmie       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  trivial      |  Milestone:  7.4.0
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  wxgui, location-wizard
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 Related update from GDAL project:
 On Sat, Nov 25, 2017 at 9:02 PM, GDAL <trac at osgeo.org> wrote:
 > #6188: OSRAutoIdentifyEPSG does not identify EPSG 3358 (North Carolina)
 >  Reporter:  Markus Neteler                      |       Owner:
 warmerdam
 >      Type:  enhancement                         |      Status:  closed
 >  Priority:  normal                              |   Milestone:  2.3.0
 > Component:  default                             |     Version:  1.11.2
 >  Severity:  normal                              |  Resolution:  fixed
 >  Keywords:  AutoIdentifyEPSG, GetAuthorityCode  |
 > Changes (by Even Rouault):
 >  * status:  new => closed
 >  * resolution:   => fixed
 >  * milestone:   => 2.3.0
 > Comment:
 >  OSRFindMatches() added in GDAL trunk should help
 >  $ gdalsrsinfo -e 'PROJCS["Lambert Conformal Conic",
 >  >     GEOGCS["grs80",
 >  >         DATUM["North_American_Datum_1983",
 SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
 >  >         PRIMEM["Greenwich",0],
 >  >         UNIT["degree",0.0174532925199433]],
 >  >     PROJECTION["Lambert_Conformal_Conic_2SP"],
 >  >     PARAMETER["standard_parallel_1",36.16666666666666],
 >  >     PARAMETER["standard_parallel_2",34.33333333333334],
 >  >     PARAMETER["latitude_of_origin",33.75],
 >  >     PARAMETER["central_meridian",-79],
 >  >     PARAMETER["false_easting",609601.22],
 >  >     PARAMETER["false_northing",0],
 >  >     UNIT["Meter",1]]'
 >  EPSG:32119
 > Ticket URL: <https://trac.osgeo.org/gdal/ticket/6188#comment:2>
 > GDAL <http://trac.osgeo.org/gdal/>
 > Geospatial Data Abstraction Library is a translator library for raster
 and vector geospatial data formats.
Ticket URL: <https://trac.osgeo.org/grass/ticket/26#comment:13>
