[GRASS-dev] Broken: GRASS-GIS/grass-ci#2401 (master - 1999c7b)
Vaclav Petras wenzeslaus at gmail.com
Wed Nov 29 08:15:32 PST 2017
This Travis fail (clang only) was not really related to GRASS source code,
only to failed download from PPA.
I have added `set -e` to the scripts:
https://trac.osgeo.org/grass/browser/grass/trunk/.travis/linux.before_install.sh
https://trac.osgeo.org/grass/browser/grass/trunk/.travis/linux.install.sh
https://trac.osgeo.org/grass/browser/grass/trunk/.travis/linux.script.sh
However, I'm not sure if there is something like that in place already,
because clearly it fails when compilation inside the main/build script
fails. So I'm not sure if this will help in the future.
Also I'm not sure if there is some occasion when it can fail and we still
want to continue.
One example of this would be the dataset download, but we are not using it,
so I removed it.
Here is the relevant part of Travis log for the original issue:
Get:92 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
trusty/main amd64 libgdal20 amd64 2.2.2+dfsg-1~trusty1 [5,110 kB]
Get:93 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
trusty/main amd64 libopenjp2-7-dev amd64 2.1.0-2.1otb1~trusty1 [25.9 kB]
Ign:94 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
trusty/main amd64 libspatialite-dev amd64 4.1.1-5ubuntu2
Ign:95 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
trusty/main amd64 libgdal-dev amd64 2.2.2+dfsg-1~trusty1
Err:94 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
  Could not connect to ppa.launchpad.net:80 (91.189.95.83), connection
timed out
Err:95 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
  Unable to connect to ppa.launchpad.net:http:
Fetched 48.4 MB in 32s (1,499 kB/s)
E: Failed to fetch
http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/pool/main/s/spatialite/libspatialite-dev_4.1.1-5ubuntu2_amd64.deb
 Could not connect to ppa.launchpad.net:80 (91.189.95.83), connection timed
out
E: Failed to fetch
http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/pool/main/g/gdal/libgdal-dev_2.2.2+dfsg-1~trusty1_amd64.deb
E: Unable to fetch some archives, maybe run apt-get update or try with
--fix-missing?
Commits:
https://trac.osgeo.org/grass/changeset/71868
https://trac.osgeo.org/grass/changeset/71869
On Wed, Nov 29, 2017 at 10:22 AM, Travis CI <builds at travis-ci.org> wrote:
> GRASS-GIS / grass-ci (master)
> Build #2401 was broken.
> 6 minutes and 40 seconds
> Václav Petráš 1999c7b Changeset →
>   docker: troubleshooting tips
> git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71867
15284696-431f-4ddb-bdfa-cd5b030d7da7
> System message:
> We are updating to Xcode 8.3! By default, macOS builds will now use Xcode
8.3 unless otherwise specified. Read more here.
> Want to know about upcoming build environment updates?
> Would you like to stay up-to-date with the upcoming Travis CI build
environment updates? We set up a mailing list for you! Sign up here.
> Documentation about Travis CI
> Need help? Mail support!
> Choose who receives these build notification emails in your configuration
file.
> Would you like to test your private code?
> Travis CI for Private Projects could be your new best friend!
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171129/343027eb/attachment-0001.html>
