[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Thu Oct 5 16:34:44 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by glynn):
Replying to [comment:36 mlennert]:
> One example: I always thought that unicode was an abstract
representation, but that in practice a unicode string was always encoded
in some encoding, with Python 3 using UTF-8 by default. Or does Python 3
really store the actual unicode code points ?
In Python, a unicode string is an array of wide characters. Typically 16
bits on Windows, 32 bits on Unix, to match the platform's wchar_t type.
This allows strings to be passed directly to the platform's APIs without
conversion.
> And what would it take for our C code to be converted to unicode ?
Re-writing almost everything that uses strings. Also, anything arriving as
a byte string would need an associated encoding or it may as well be
discarded.
Internally, strings could be stored either as wchar_t[] or as char[] using
UTF-8. But whichever representation was used, you would need to perform
conversions for some platforms: Unix uses char[] and doesn't much care
about encoding, Windows uses wchar_t[] (char[]-based APIs such as fopen()
are considered "legacy" and can't be used with e.g. filenames which aren't
valid in the current codepage).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:37>
