[GRASS-dev] Force --v flag whenever -l is instructed
Nikos Alexandris
nik at nikosalexandris.net
Mon Oct 9 03:18:29 PDT 2017
* Moritz Lennert <moritz.lennert at ulb.ac.be> [2017-10-09 10:59:25 +0200]:
>On 07/10/17 10:39, Nikos Alexandris wrote:
>>In a grassy script, how can I force verbosity, i.e. --v whenever a flag
>>-l is instructed? Which will lead to
>>env['GRASS_VERBOSE'] = '3'
>>i.some.module input=some_input -l
>>should be identical to
>>i.some.module input=some_input -l --v
>>The following is, of course, not working:
>>#%rules
>>#% requires_all: -l,--v
>>#%end
>I don't think the -- flags are covered by the rules, so I think you
>have to do this in the code, i.e. something like this:
>if flags['l']:
Merci Moritz,
I tested already (before asking)
env = os.environ.copy()
if list_only:
but it does not work.
Aren't there other ways?
Thank you again, N
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171009/a054131a/attachment.sig>
