[GRASS-dev] [GRASS GIS] #3425: regression in v.in.ogr -f 7.3 7 Oct (possibly earlier)
GRASS GIS trac at osgeo.org
Wed Oct 11 03:00:05 PDT 2017
  Reporter:  rsbivand     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by rsbivand):
 {{{rgdal::ogrDrivers[,1]}}} is:
 > ogrDrivers()[,1]
  [1] "AeronavFAA"     "AmigoCloud"     "ARCGEN"         "AVCBin"
  [5] "AVCE00"         "BNA"            "CAD"            "Carto"
  [9] "Cloudant"       "CouchDB"        "CSV"            "CSW"
 [13] "DGN"            "DXF"            "EDIGEO"         "ElasticSearch"
 [17] "ESRI Shapefile" "Geoconcept"     "GeoJSON"        "Geomedia"
 [21] "GeoRSS"         "GFT"            "GML"            "GMLAS"
 [25] "GPKG"           "GPSBabel"       "GPSTrackMaker"  "GPX"
 [29] "HTF"            "HTTP"           "Idrisi"         "Interlis 1"
 [33] "Interlis 2"     "JML"            "KML"            "MapInfo File"
 [37] "Memory"         "MSSQLSpatial"   "NAS"            "netCDF"
 [41] "ODBC"           "ODS"            "OGR_GMT"        "OGR_PDS"
 [45] "OGR_SDTS"       "OGR_VRT"        "OpenAir"        "OpenFileGDB"
 [49] "OSM"            "PCIDSK"         "PDF"            "PGDUMP"
 [53] "PGeo"           "PLSCENES"       "PostgreSQL"     "REC"
 [57] "S57"            "SEGUKOOA"       "SEGY"           "Selafin"
 [61] "SQLite"         "SUA"            "SVG"            "SXF"
 [65] "TIGER"          "UK .NTF"        "VDV"            "VFK"
 [69] "Walk"           "WAsP"           "WFS"            "XLS"
 [73] "XLSX"           "XPlane"
 from (rgdal/src/ogrdrivers.cpp) line 71:
       SET_STRING_ELT(VECTOR_ELT(ans, 0), i,
         COPY_TO_USER_STRING(poDriver->GetName()));
 In 7.2.2, the matches work in rgrass7:::.read_vect_non_plugin, line 80 in
 rgrass7/R/vect_link.R:
     ogrD <- rgdal::ogrDrivers()
     ogrDw <- gsub(" ", "_", ogrD$name[ogrD$write])
 # guess GRASS v.out.ogr capability from rgdal
     ogrDGRASS <- execGRASS("v.in.ogr", flags=ifelse(ignore.stderr, c("f",
                            "quiet"), "f"), intern=TRUE,
                            ignore.stderr=ignore.stderr)
     ogrDGRASSs <- gsub(" ", "_", sapply(strsplit(ogrDGRASS, ": "), "[",
 2))
     candDrivers <- gsub(" ", "_", sort(intersect(ogrDGRASSs, ogrDw)))
 In 7.3, ogrDGRASSs is:
 Browse[2]> sort(ogrDGRASSs)
  [1] "Aeronav_FAA"
  [2] "AmigoCloud"
  [3] "Arc/Info_Binary_Coverage"
  [4] "Arc/Info_E00_(ASCII)_Coverage"
  [5] "Arc/Info_Generate"
  [6] "Atlas_BNA"
  [7] "AutoCAD_Driver"
  [8] "AutoCAD_DXF"
  [9] "Carto"
 [10] "Cloudant_/_CouchDB"
 [11] "Comma_Separated_Value_(.csv)"
 [12] "CouchDB_/_GeoCouch"
 [13] "Czech_Cadastral_Exchange_Data_Format"
 [14] "Elastic_Search"
 [15] "EPIInfo_.REC_"
 [16] "ESRI_FileGDB"
 [17] "ESRI_Personal_GeoDatabase"
 [18] "ESRI_Shapefile"
 [19] "French_EDIGEO_exchange_format"
 [20] "Geoconcept"
 [21] "Geography_Markup_Language_(GML)"
 [22] "Geography_Markup_Language_(GML)_driven_by_application_schemas"
 [63] "SEG-Y"
 [64] "Selafin"
 [65] "SQLite_/_Spatialite"
 [66] "Storage_and_eXchange_Format"
 [67] "Tim_Newport-Peace's_Special_Use_Airspace_Format"
 [68] "U.S._Census_TIGER/Line"
 from vector/v.in.ogr/main.c line 404
             fprintf(stdout, " %s (%s): %s\n",
                     GDALGetDriverShortName(hDriver),
                     pszRWFlag, GDALGetDriverLongName(hDriver));
 where {{{GDALGetDriverShortName(hDriver)}}} calls {{{GDALDriver
 *>(hDriver)->GetDescription()}}}, which looks like my
 {{{poDriver->GetDescription()}}}. I can't see why the string values differ
 for the same GDAL.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3425#comment:2>
