[GRASS-dev] [GRASS GIS] #3425: regression in v.in.ogr -f 7.3 7 Oct (possibly earlier)
GRASS GIS trac at osgeo.org
Wed Oct 11 05:07:18 PDT 2017
  Reporter:  rsbivand     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  major        |  Milestone:
 Component:  Vector       |    Version:  svn-trunk
Resolution:  fixed        |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:5 rsbivand]:
 > Regression resolved with revision 61:
 >     gv <- unname(read.dcf(textConnection(gsub("=", ":",
 >       execGRASS("g.version", flags="g", intern=TRUE))))[1,1])
 >     if (gv < "7.3") {
 >       ogrDGRASSs <- gsub(" ", "_", sapply(strsplit(ogrDGRASS, ": "),
 "[", 2))
 >     } else {
 >       strs <- sapply(strsplit(ogrDGRASS, ": "), "[", 1)
 >       ogrDGRASSs <- gsub(" ", "_", gsub(" $", "",
 >         substring(strs, 2, nchar(strs)-5)))
 Why not
       ogrDGRASSs <- gsub(" ", "_", trimws(sapply(strsplit(ogrDGRASS, "
 [(]"), "[", 1)))
 which works with all versions?
 This would also work with `r.in.gdal -f`. The outputs of `r.in.gdal -f`
 and `v.in.ogr -f` already have the same structure (also in GRASS 7.2),
 independent of the GDAL version used.
 Starting with GDAL 2.0, the outputs of `gdalinfo --formats` and `ogrinfo
 --formats` also have the same structure.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3425#comment:7>
