[GRASS-dev] [GRASS GIS] #3426: Impossible to not compute shape statistics with i.segment.stats
GRASS GIS trac at osgeo.org
Mon Oct 16 07:53:21 PDT 2017
  Reporter:  tgrippa      |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Addons       |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by mlennert):
 Replying to [ticket:3426 tgrippa]:
 > Hi,
 > It seems it is impossible to avoid computation of shape statistics using
 i.segment.stats.
 > When unticking all 'area measurements' in the GUI or when not sepcifying
 the 'area_measures' parameter in command line, the standards shape
 statistics are anyway computed.
 The same is true for the raster measures. In the command line you can use
 raster_statistics= and/or area_measures= (i.e. no measures after the '=')
 to avoid calculation of the measures, but this is not possible in the GUI,
 AFAICT. I don't know if there is a possibility to provide default answers
 to a non-required parameter and allow to leave it empty in the GUI. The
 easiest solution would be to not provide any default answers.
 If someone has another idea, I would love to hear it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3426#comment:1>
