[GRASS-dev] [GRASS GIS] #3427: Ask for improvement of i.segment.stats : Allow parallel work for different rasters
trac at osgeo.org
Mon Oct 16 22:47:53 PDT 2017
rasters
Reporter: tgrippa | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: segment | CPU: Unspecified
Platform: Unspecified |
I would like to ask for an improvement of i.segment.stats add-on. For the
moment, the processing workflow is serial (objects statistics computed for
the first band, e.g. blue, then on red, then on green, etc..). It could be
great if the process could be parallelized on X different cores. I'm often
computing objects statistics on +10 different rasters. This improvement
would allow for saving a lot of processing time.
Cheers,
PS: Thank you for making GRASS more and more efficient for Object-Based
image analysis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3427>
