[GRASS-dev] prefer GeoPackage over Shapefile
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Oct 18 06:07:28 PDT 2017
Hi Evan,
oh, thanks for the typo, fixed in my code ;-)
There is driver check in the code
https://svn.osgeo.org/grass/grass/trunk/vector/v.out.ogr/main.c
line 457
for (i = 0; i < OGRGetDriverCount(); i++) {
I could probably commit, but before I do, I would like to get confirmed by
PSC, this is OK to GRASS community.
Jachym
P.S. I've prepared similar patch for QGIS for those, who are interested
https://github.com/qgis/QGIS/pull/5385
st 18. 10. 2017 v 14:36 odesÃlatel Even Rouault <even.rouault at spatialys.com>
napsal:
> On mercredi 18 octobre 2017 12:28:36 CEST Jachym Cepicky wrote:
> > Hi,
> > I would like to submit following commit to GRASS GIS - master
> > Index: vector/v.out.ogr/args.c
> > --- vector/v.out.ogr/args.c (revision 71566)
> > +++ vector/v.out.ogr/args.c (working copy)
> > @@ -32,7 +32,7 @@
> > options->format->type = TYPE_STRING;
> > options->format->required = YES;
> > options->format->multiple = NO;
> > - options->format->answer = "ESRI_Shapefile";
> > + options->format->answer = "DPKG";
> > options->format->options = OGR_list_write_drivers();
> > options->format->description = _("Data format to write");
> > any objections?
> I'm not a GRASS dev, but do I have a major objection... There's a typo in
> your
> patch ;-) Should be GPKG
> Joke aside, the SQLite dependency in GDAL builds is optional, so in theory
> you
> could have a GDAL build without SQLite/GPKG support. But this is really
> unlikely in practice as no sane packager would do that. Perhaps checking
> if
> the GPKG driver is there would be safer, and if not fallback to good old
> shapefile.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171018/23a6ecf3/attachment.html>
