[GRASS-dev] r.plane commits breaks winGRASS builds
Helmut Kudrnovsky hellik at web.de
Fri Oct 20 00:16:44 PDT 2017
looking into winGRASS build logs:
https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71566-385/error.log
https://wingrass.fsv.cvut.cz/grass73/x86_64/logs/log-r71567-385/error.log
recent r.plane commits seems to break winGRASS builds:
GRASS GIS 7.3.svn r71567 compilation log
Started compilation: Thu Oct 19 23:40:19     2017
Errors in:
/c/msys64/usr/src/grass_trunk/scripts/r.plane
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fri Oct 20 00:17:27     2017
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
