[GRASS-dev] [GRASS GIS] #3428: Set OGC GeoPackage as default export format
trac at osgeo.org
Sat Oct 21 06:57:16 PDT 2017
Reporter: jachym | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.4.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
How to deal with this packaging case?
On Wed, Oct 18, 2017 at 2:36 PM, Even Rouault wrote:
> the SQLite dependency in GDAL builds is optional, so in theory you
> could have a GDAL build without SQLite/GPKG support. But this is really
> unlikely in practice as no sane packager would do that. Perhaps
checking if
> the GPKG driver is there would be safer, and if not fallback to good old
> shapefile.
... hence add a #ifdef condition to the parser default?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3428#comment:2>
