[GRASS-dev] Microseconds in timestamps in abstract_space_time_dataset.py
Nikos Alexandris nik at nikosalexandris.net
Sat Oct 21 08:22:06 PDT 2017
Thanks. Looked at the revision to learn a bit more.
I have no more errors.
Nikos
* Sören Gebbert <soerengebbert at googlemail.com> [2017-10-21 17:04:55 +0200]:
>Please try r71573 from grass_trunk, test your case and report any problems.
>Best regards
>Sören
>2017-10-21 10:08 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
>> Dear Soeren & Co,
>> the following stumbles in timestamps with microseconds. See:
>> t.info lst -g
>> id=lst at lst
>> creator=nik
>> temporal_type=absolute
>> creation_time=2017-10-16 09:10:15.689554
>> modification_time=2017-10-16 09:47:01.646840
>> semantic_type=mean
>> start_time=2013-04-13 10:00:09.935625
>> end_time=2017-04-24 09:57:43.257139
>> granularity=1 second
>> First item is:
>> t.rast.list lst -u column=name,start_time |head -1
>> lst_LC81920282013103LGN01|2013-04-13 10:00:09.935625
>> The error:
>> t.rast.aggregate input=lst output=lst_yearly basename=lst_yearly suffix=gran
>> granularity="1 year" method=average --o
>> 0..20..40..60..80..100
>> 0..100
>> 0..Traceback (most recent call last):
>>  File "/osgeo/grass72/dist.x86_64-pc-linux-gnu/scripts/t.rast.aggregate",
>> line 213, in <module>
>>    main()
>> line 203, in main
>>    sp.get_relative_time_unit(),  dbif)
>>  File
>> "/osgeo/grass72/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/register.py",
>> line 499, in register_map_object_list
>>    file=filename, dbif=dbif)
>>  File
>> line 341, in register_maps_in_space_time_dataset
>>    sp.update_from_registered_maps(dbif)
>>  File
>> "/osgeo/grass72/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/abstract_space_time_dataset.py",
>> line 2376, in update_from_registered_maps
>>    tstring, time_format)
>>  File "/usr/lib64/python2.7/_strptime.py", line 335, in _strptime
>>    data_string[found.end():])
>> ValueError: unconverted data remains: .935625
>> Two possible updates. Remove microseconds altogether:
>> Index: abstract_space_time_dataset.py
>> --- abstract_space_time_dataset.py      (revision 71469)
>> +++ abstract_space_time_dataset.py      (working copy)
>> @@ -2368,6 +2368,8 @@
>>                     # Convert the unicode string into the datetime format
>>                     if self.is_time_absolute():
>>                         if tstring.find(":") > 0:
>> +                            if tstring.find('.') > 0:
>> +                                tstring = tstring.split('.')[0]
>>                             time_format = "%Y-%m-%d %H:%M:%S"
>>                         else:
>>                             time_format = "%Y-%m-%d"
>> Or, retain them:
>> @@ -2367,7 +2367,9 @@
>>                     tstring = row[0]
>> -                        if tstring.find(":") > 0:
>> +                        if tstring.find(":") and tstring.find(".") > 0:
>> +                            time_format = "%Y-%m-%d %H:%M:%S.%f"
>> +                        elif tstring.find(":") > 0:
>>                         else:
>> As ignorant as I am, I'd prefer the second. Would this cause problems to
>> t.* operations?
>> Thanks, Nikos
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171021/2b36e1f5/attachment-0001.sig>
