[GRASS-dev] d.mon Segmentation fault
Nikos Alexandris
nik at nikosalexandris.net
Sat Oct 21 15:30:25 PDT 2017
Since some time, I get Segmentation fault when I try to launch `d.mon wx0`.
I don't use'm much, so I didn't bother.
Now, I got to update my system and I would like to fix this.
If anyone could hint where to look at...
D1/5: G_set_program_name(): g.gisenv
D3/5: G_option_to_separator(): key = separator -> sep = '
D3/5: G_option_to_separator(): key = separator -> sep = '/'
g72 landsat Location l8 Mapset @PERMANENT ~ [1/547]
→ d.mon -l
D1/5: G_set_program_name(): d.mon
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT
D2/5: G__temp_element(): .tmp/carbon (tmp=0)
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS
No monitors running
g72 landsat Location l8 Mapset @PERMANENT ~ [2/548]
→ d.mon wx0
D1/5: Monitor width/height = 720/480
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/env
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/cmd
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/leg
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/render.py
D1/5: Monitor name=wx0, pyfile = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/render.py
D2/5: G_file_name(): path = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/map.ppm
D1/5: Monitor name=wx0, envfile=/geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/env
D1/5: Monitor name=wx0, cmdfile = /geo/grassdb/samples/landsat/l8/PERMANENT/.tmp/carbon/MONITORS/wx0/cmd
g72 landsat Location l8 Mapset @PERMANENT ~ [3/549]
→ d.mon -l
Segmentation fault
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171022/0563ff35/attachment.sig>
