[GRASS-dev] Invalid timestamp file for raster
Sören Gebbert
soerengebbert at googlemail.com
Mon Oct 23 14:08:12 PDT 2017
JFYI:
The temporal framework (used in t.register) ignores fractions of a
second. The smallest temporal granule is a second. Hence, it doesn't
make sense to use time-stamps for maps with fractions of a second in
the temporal framework.
Best regards
Sören
2017-10-23 22:54 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Hi Nikos,
> Have you tried with t.register?
> You would need to set the start_time="2013-04-13 10:00:09.935626" plus an
> increment="10 seconds". I have not tested, but it should work.
> I think it's better than r.timestamp if you want to create time series, even
> though it would be great to fix the bug in r.timestamp, anyway.
> Cheers,
> Vero
> El 23 oct. 2017 7:38 p.m., "Nikos Alexandris" <nik at nikosalexandris.net>
> escribió:
> Nikos:
>>> This
>>> r.timestamp B1 date='13 apr 2013 10:00:09.935626' && r.timestamp B1
>>> WARNING: Invalid timestamp file for raster map <B1@>
>>> does not work. Why?
> Markus N:
>> GRASS 7.2.3svn (nc_spm_08_grass7):~ > r.mapcalc "B1 = 2"
>> 100%
>> GRASS 7.2.3svn (nc_spm_08_grass7):~ > r.timestamp B1 date='13 apr
>> The error message is in lib/gis/timestamp.c, line 301. With debug:
>> GRASS 7.2.3svn (nc_spm_08_grass7):~ > g.gisenv set=DEBUG=1
>> D1/1: G_set_program_name(): g.gisenv
>> D1/1: G_set_program_name(): r.timestamp
>> D1/1: G_find_raster(): name=B1 mapset=
>>> The following do work:
>>> r.timestamp B1 date='13 apr 2013 10:00:19.935626' && r.timestamp B1
>>> 13 Apr 2013 10:00:19.935626
>> D1/1: G_find_raster(): name=B1 mapset=user1
>> There is apparently a parsing bug in 10:00:0x <<-- 0x (while 1x etc
>> work).
> Obviously.
> Here a quick test for 0x:
> function seconds { printf "%02d" $1; }
> for SEC in `seq 0 1 59` ;do echo $(seconds $SEC) && r.timestamp B1 date="13
> apr 2013 10:00:$(seconds $SEC).935626" && r.timestamp B1 ;done
> 00
> 01
> 02
> 03
> 04
> 05
> 06
> 07
> 08
> 09
> 10
> 13 Apr 2013 10:00:10.935626
> 11
> 13 Apr 2013 10:00:11.935626
> 12
> 13 Apr 2013 10:00:12.935626
> [..rest is fine..]
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
