[GRASS-dev] Invalid timestamp file for raster
Nikos Alexandris nik at nikosalexandris.net
Mon Oct 23 15:59:15 PDT 2017
* Veronica Andreo <veroandreo at gmail.com> [2017-10-23 22:54:03 +0200]:
>Hi Nikos,
>Have you tried with t.register?
>You would need to set the start_time="2013-04-13 10:00:09.935626" plus an
>increment="10 seconds". I have not tested, but it should work.
>I think it's better than r.timestamp if you want to create time series,
>even though it would be great to fix the bug in r.timestamp, anyway.
I am r.timestamp-ing Landsat bands while importing them via a script and
sourcing meta from MTL files. I noticed that in some cases, the time
stamping did not work.
Cheers, Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171024/88009b42/attachment.sig>
