[GRASS-dev] Invalid timestamp file for raster
Sören Gebbert soerengebbert at googlemail.com
Tue Oct 24 03:56:43 PDT 2017
Hi Nikos,
the strategy that i use is to create an input file for t.register that
contains the raster names and the time stamps for registration:
map_name | start_time | end_time
In case of Landsat scenes, there are not end-time stamps. Create this
file while importing and fill it with map names and time stamps.
Use this file with t.register and register all maps in a STRDS that
have been imported. I would suggest to create a single STRDS for each
band, so you can use map algebra for computation.
Best regards
Sören
2017-10-24 0:59 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> * Veronica Andreo <veroandreo at gmail.com> [2017-10-23 22:54:03 +0200]:
>> Hi Nikos,
>> Have you tried with t.register?
>> You would need to set the start_time="2013-04-13 10:00:09.935626" plus an
>> increment="10 seconds". I have not tested, but it should work.
>> I think it's better than r.timestamp if you want to create time series,
>> even though it would be great to fix the bug in r.timestamp, anyway.
> I am r.timestamp-ing Landsat bands while importing them via a script and
> sourcing meta from MTL files. I noticed that in some cases, the time
> stamping did not work.
> Cheers, Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
