[GRASS-dev] GRASS GIS raster files: LZW compression?
Markus Metz
markus.metz.giswork at gmail.com
Thu Oct 26 00:25:08 PDT 2017
On Wed, Oct 25, 2017 at 10:40 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> while playing with the SRTM 30m world I see that there is a difference
> of 66GB in size between LZ4 (larger) and DEFLATE (smaller). While this
> is not a surprise I was wondering if LZW compression could be brought
> back. AFAIK the license issue is gone for a while and indeed GRASS got
> a special permit back in 1988 according to the old source code.
> Would that make sense?
You could test with compress (LZW) and gzip (DEFLATE based on LZ77) if that
would make sense.
Implementation would be a bit of an effort: either adapt from the source
code of compress or from GDAL's LZW compression for Tiff.
Markus M
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171026/a13e6c2b/attachment.html>
