[GRASS-dev] [GRASS GIS] #2919: Use SFD above this threshold - infinity doesn't work in r.stream.extract
GRASS GIS trac at osgeo.org
Sun Oct 29 04:00:41 PDT 2017
  Reporter:  PitStop  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.2.3
 Component:  Raster   |    Version:  svn-releasebranch72
Resolution:           |   Keywords:  r.stream.extract
       CPU:  x86-64   |   Platform:  MSWindows 8
Comment (by marisn):
 Replying to [comment:10 hellik]:
 > > Seems that "infinity" is not understood by the parser?
 https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/raster/r.stream.extract/main.c#L195
 > yes, it seems to be a parser issue. but why it works then in linux?
 My guess - input.d8cut->answer contains extra chars (CR/LF issue?) and
 thus changing line to read:
 if (strncmp(input.d8cut->answer, "infinity", 8) == 0) {
 would solve the issue. Still, if it is so, then it is worth to digg deeper
 to see why it is failing as strcmp is used in many modules.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919#comment:11>
