[GRASS-dev] Compilation options
Anna Petrášová
kratochanna at gmail.com
Sun Oct 29 04:31:24 PDT 2017
v.surf.rst in trunk has nproc parameter, have you tried to use it?
Anna
On Oct 29, 2017 6:51 AM, "Stefan Blumentrath" <Stefan.Blumentrath at nina.no>
wrote:
Hei Anna,
Thanks for looking into this.
I did some tests with GRASS 7.2.1svn (r70188) and GRASS 7.3.svn (r70829)
both compiled with --with-openmp
It seems that r.proj does not use multiple threads in GRASS 7.2 (not tested
in 7.3. yet). v.surf.rst uses more cores in GRASS 7.2 with OpenMP but that
does not bring down execution time at all. OpenMP seems to be disabled for
v.surf.rst in GRASS 7.3. v.surf.bspline however, is significantly faster in
GRASS 7.3 with OpenMP...
I will do some more, systematic tests and update the wiki entry as far as I
can, if not someone with knowledge gets there first...
Cheers
Stefan
P.S.: Some preliminary test results:
# OpenMP support test
$ OMP_NUM_THREADS=10
$ export OMP_NUM_THREADS
$ time v.surf.rst input=points elevation=test --o --qq
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
$ time v.surf.bspline elevrand column=value output=elev_full --o
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
-----Original Message-----
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: fredag 27. oktober 2017 17.00
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: GRASS developers list (grass-dev at lists.osgeo.org) <
grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] Compilation options
On Tue, Oct 24, 2017 at 10:27 AM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Hi again,
> Seek and ye shall find…
> So, there is:
> https://grasswiki.osgeo.org/wiki/OpenMP#OpenMP_support_in_GRASS_7 and
> https://grasswiki.osgeo.org/wiki/GPU
> Which helped me a bit further.
> However, my impression is that not all info there (esp. on OpenMP) is
> up to date (e.g. latest development like here:
> https://lists.osgeo.org/pipermail/grass-dev/2017-August/085711.html).
> Neither did it became very clear to me which modules already have
> robust and working support and which are just candidates or where
> initial implementations are available (sometimes outside the code
> base)…
I updated it slightly to reflect the new modules, as always, more work is
needed on that page.
Anna
> Cheers
> Stefan
> From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf
> Of Stefan Blumentrath
> Sent: mandag 23. oktober 2017 09.24
> To: GRASS developers list (grass-dev at lists.osgeo.org)
> <grass-dev at lists.osgeo.org>
> Subject: [GRASS-dev] Compilation options
> Dear all,
> Does someone of you know which modules benefit from --with-openmp and
> --with-opencl compilation options?
> I found this explanation of compilation options:
> https://grass.osgeo.org/grass72/source/snapshot/REQUIREMENTS.html
> But it does not cover OpenCL or OpenMP (as well as some few more other
> option).
> If I wanted to find out myself, could I just search the code for
> modules that import the relevant headers of the respective libraries?
> Or is that a bit more complex?
> Another question is if it would be recommended to use the different
> options, as I understood e.g. using --with-pthread is not necessarily
> a good choice…
> Thanks in advance.
> Cheers
> Stefan
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171029/eaf8e900/attachment-0001.html>
