[GRASS-dev] Compilation options
Anna Petrášová
kratochanna at gmail.com
Mon Oct 30 04:24:12 PDT 2017
I just ported r.sun.mp from addons to r.sun, so you are welcome to test
that as well.
Anna
On Oct 30, 2017 5:28 AM, "Stefan Blumentrath" <Stefan.Blumentrath at nina.no>
wrote:
Thanks Anna,
Yes, now I can confirm that it works. The problem was that I did not adjust
the region to where the points are which influenced computation so OpenMP
did not kick-in.
So now:
g.region -p vector=elev_lidrural_mrpts res=1 -a
time v.surf.rst --overwrite input=elev_lidrural_mrpts at PERMANENT
elevation=test nprocs=10
Reading features from vector map ...
WARNING: Strip exists with insufficient data
Ignoring 701 points (too dense)
Processing segments in parallel...
Starting parallel work
WARNING: Overshoot - increase in tension suggested. Overshoot occurs at
(85,878) cell. Z-value 158.741920, zmin 102.227686, zmax
153.065828.
100%
v.surf.rst complete.
real 0m19.670s
user 2m19.833s
sys 0m0.446s
Compared to:
real 2m0.889s
user 2m0.332s
sys 0m0.251s
Cool!
Cheers
Stefan
P.S.: using /usr/bin/time -v it seems that RAM usage increased by a factor
of ~2.25 between 1 and 10 cores...
-----Original Message-----
From: Anna Petrášová [mailto:kratochanna at gmail.com]
Sent: søndag 29. oktober 2017 23.00
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: GRASS-dev <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] Compilation options
On Sun, Oct 29, 2017 at 4:30 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Thanks for the hint.
> I just tried:
> time v.surf.rst elevrand zcol=value elevation=elev_full --o nprocs=10
> real 0m33.814s
> user 0m35.786s
> sys 0m0.126s
> Seems, that also with nprocs=10 and OMP_NUM_THREADS=10 v.surf.rst only
> uses one CPU in GRASS 7.3.svn (despite the message about parallel
> work)…
For me it works, try different dataset, you might see more difference for
larger datasets maybe:
GRASS 7.3.svn (nc_spm_08_coastal):~/dev/grass/trunk2 > time v.surf.rst
--overwrite input=elev_lidrural_mrpts at PERMANENT elevation=test
nprocs=4
WARNING: Some points outside of region (ignored)
WARNING: There are points outside specified 2D/3D region - 9663 points
ignored
Ignoring 511 points (too dense)
(662,749) cell. Z-value 98.513438, zmin 103.513005, zmax
153.065828.
real 0m58.009s
user 3m41.476s
sys 0m0.304s
> Cheers
> Stefan
> Sent: søndag 29. oktober 2017 12.31
> Subject: RE: [GRASS-dev] Compilation options
> v.surf.rst in trunk has nproc parameter, have you tried to use it?
> Anna
> On Oct 29, 2017 6:51 AM, "Stefan Blumentrath"
> wrote:
> Hei Anna,
> Thanks for looking into this.
> I did some tests with GRASS 7.2.1svn (r70188) and GRASS 7.3.svn
> (r70829) both compiled with --with-openmp
> It seems that r.proj does not use multiple threads in GRASS 7.2 (not
> tested in 7.3. yet). v.surf.rst uses more cores in GRASS 7.2 with
> OpenMP but that does not bring down execution time at all. OpenMP
> seems to be disabled for v.surf.rst in GRASS 7.3. v.surf.bspline
> however, is significantly faster in GRASS 7.3 with OpenMP...
> I will do some more, systematic tests and update the wiki entry as far
> as I can, if not someone with knowledge gets there first...
> Cheers
> Stefan
> P.S.: Some preliminary test results:
> # OpenMP support test
> $ OMP_NUM_THREADS=10
> $ export OMP_NUM_THREADS
> $ time v.surf.rst input=points elevation=test --o --qq
> real 51m42.224s
> user 398m2.766s
> sys 0m18.874s
> $ OMP_NUM_THREADS=1
> real 53m22.508s
> user 53m10.607s
> sys 0m4.793s
> $ time v.surf.bspline elevrand column=value output=elev_full --o
> real 0m20.509s
> user 3m11.412s
> sys 0m1.963s
> $ OMP_NUM_THREADS=1
> real 1m15.434s
> user 1m14.738s
> sys 0m0.447s
> Sent: fredag 27. oktober 2017 17.00
> Cc: GRASS developers list (grass-dev at lists.osgeo.org)
> On Tue, Oct 24, 2017 at 10:27 AM, Stefan Blumentrath
> <Stefan.Blumentrath at nina.no> wrote:
>> Hi again,
>> Seek and ye shall find…
>> So, there is:
>> https://grasswiki.osgeo.org/wiki/OpenMP#OpenMP_support_in_GRASS_7 and
>> https://grasswiki.osgeo.org/wiki/GPU
>> Which helped me a bit further.
>> However, my impression is that not all info there (esp. on OpenMP) is
>> up to date (e.g. latest development like here:
>> https://lists.osgeo.org/pipermail/grass-dev/2017-August/085711.html).
>> Neither did it became very clear to me which modules already have
>> robust and working support and which are just candidates or where
>> initial implementations are available (sometimes outside the code
>> base)…
> I updated it slightly to reflect the new modules, as always, more work
> is needed on that page.
> Anna
>> Cheers
>> Stefan
>> From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf
>> Of Stefan Blumentrath
>> Sent: mandag 23. oktober 2017 09.24
>> To: GRASS developers list (grass-dev at lists.osgeo.org)
>> Subject: [GRASS-dev] Compilation options
>> Dear all,
>> Does someone of you know which modules benefit from --with-openmp and
>> --with-opencl compilation options?
>> I found this explanation of compilation options:
>> https://grass.osgeo.org/grass72/source/snapshot/REQUIREMENTS.html
>> But it does not cover OpenCL or OpenMP (as well as some few more
>> other option).
>> If I wanted to find out myself, could I just search the code for
>> modules that import the relevant headers of the respective libraries?
>> Or is that a bit more complex?
>> Another question is if it would be recommended to use the different
>> options, as I understood e.g. using --with-pthread is not necessarily
>> a good choice…
>> Thanks in advance.
>> Cheers
>> Stefan
>> grass-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171030/d4e9ee22/attachment.html>
