[GRASS-dev] [GRASS GIS] #3413: r.in.gdal/v.in.ogr: add new config option to support GDAL/OGR configuration options
GRASS GIS trac at osgeo.org
Mon Sep 4 11:53:02 PDT 2017
options
 Reporter:  mmetz            |      Owner:  grass-dev@…
     Type:  enhancement      |     Status:  new
 Priority:  normal           |  Milestone:  7.4.0
Component:  Datasets         |    Version:  svn-trunk
 Keywords:  GDAL/OGR import  |        CPU:  All
 Platform:  All              |
 GDAL/OGR support setting of various configuration options [1].
 For GDAL/OGR utilities, these configuration options can be set with
 <GDAL|OGR tool> --config <Key> <Value>
 These configuration options may be general, GDAL specific, OGR specific,
 or applicable to a particular GDAL/OGR driver.
 Some external data can only be successfully imported if non-default
 configuration options are used. Therefore r.in.gdal/v.in.ogr should have a
 new `config` option to support setting of these configuration options with
 `CPLSetConfigOption()`.
 [1] [https://trac.osgeo.org/gdal/wiki/ConfigOptions]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3413>
