[GRASS-dev] [GRASS GIS] #3414: v.import: ERROR: Invalid e-w resolution field: 0 when importing EU_LAEA point into Sinusoidal location
GRASS GIS trac at osgeo.org
Wed Sep 6 07:03:12 PDT 2017
  Reporter:  neteler             |      Owner:  grass-dev@…
      Type:  defect              |     Status:  new
  Priority:  normal              |  Milestone:  7.2.2
 Component:  Projections/Datums  |    Version:  svn-trunk
Resolution:                      |   Keywords:  v.import
       CPU:  Unspecified         |   Platform:  Linux
Comment (by mlennert):
 Interestingly:
 g.proj georef=point_eu_laea.shp location=test2
 Essai d'ouverture à l'aide d'OGR...
 ...réussi.
 Location <test2> created
 You can switch to the new location by
 `g.mapset mapset=PERMANENT location=test2`
 but
 v.in.ogr point_eu_laea.shp location=test
 ATTENTION: All available OGR layers will be imported into vector map
            <point_eu_laea>
 Location <test> created
 ERREUR :Invalid e-w resolution field: 0
 Both are created, but:
 diff -u test/PERMANENT/ test2/PERMANENT/
 diff -u test/PERMANENT/.bashrc test2/PERMANENT/.bashrc
 --- test/PERMANENT/.bashrc      2017-09-06 15:54:44.389963786 +0200
 +++ test2/PERMANENT/.bashrc     2017-09-06 15:54:55.545841900 +0200
 @@ -1,5 +1,5 @@
  test -r ~/.alias && . ~/.alias
 -PS1='GRASS 7.3.svn (test):\w > '
 +PS1='GRASS 7.3.svn (test2):\w > '
  grass_prompt() {
         LOCATION="`g.gisenv get=GISDBASE,LOCATION_NAME,MAPSET
 separator='/'`"
         if test -d "$LOCATION/grid3/G3D_MASK" && test -f
 "$LOCATION/cell/MASK" ; then
 diff -u test/PERMANENT/DEFAULT_WIND test2/PERMANENT/DEFAULT_WIND
 --- test/PERMANENT/DEFAULT_WIND 2017-09-06 15:51:39.891978100 +0200
 +++ test2/PERMANENT/DEFAULT_WIND        2017-09-06 15:52:13.227614355
 +0200
 @@ -10,9 +10,9 @@
  n-s resol:  0
  top:        1.000000000000000
  bottom:     0.000000000000000
 -cols3:      1
 -rows3:      1
 +cols3:      20
 +rows3:      20
  depths:     1
 -e-w resol3: 1
 -n-s resol3: 1
 +e-w resol3: 0
 +n-s resol3: 0
  t-b resol:  1
 Common subdirectories: test/PERMANENT/sqlite and test2/PERMANENT/sqlite
 Only in test/PERMANENT/: .tmp
 diff -u test/PERMANENT/WIND test2/PERMANENT/WIND
 --- test/PERMANENT/WIND 2017-09-06 15:51:39.891978100 +0200
 +++ test2/PERMANENT/WIND        2017-09-06 15:52:13.227614355 +0200
 @@ -10,9 +10,9 @@
  n-s resol:  0
 -cols3:      1
 -rows3:      1
 +cols3:      20
 +rows3:      20
  depths:     1
 -e-w resol3: 1
 -n-s resol3: 1
 +e-w resol3: 0
 +n-s resol3: 0
  t-b resol:  1
 and in both I get:
 g.proj -p
 because DEFAULT_WIND/WIND contains:
 proj:       99
 zone:       0
 north:      1205000
 south:      1205000
 east:       3674000
 west:       3674000
 cols:       20
 rows:       20
 e-w resol:  0
 n-s resol:  0
 cols3:      1
 rows3:      1
 depths:     1
 e-w resol3: 1
 n-s resol3: 1
 t-b resol:  1
 which seems logical as a point does not have dimensions, but the default
 region should still be defined with one cell and a resolution of 1....
 So, yes, there seems to be a link to #2878...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3414#comment:2>
