[GRASS-dev] [GRASS GIS] #3414: v.import: ERROR: Invalid e-w resolution field: 0 when importing EU_LAEA point into Sinusoidal location
trac at osgeo.org
Wed Sep 6 09:02:54 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Projections/Datums | Version: svn-trunk
Resolution: | Keywords: v.import
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
Replying to [comment:3 mmetz]:
> Replying to [comment:2 mlennert]:
> > [...] I get:
> > g.proj -p
> > ERREUR :Invalid e-w resolution field: 0
> > because DEFAULT_WIND/WIND contains:
> > proj: 99
> > zone: 0
> > north: 1205000
> > south: 1205000
> > east: 3674000
> > west: 3674000
> > which seems logical as a point does not have dimensions, but the
default region should still be defined with one cell and a resolution of
1....
> A simple solution would be to add/subtract 0.5 if north == south and/or
east == west with rows and/or cols set to 1. For latlong, this is only
guaranteed to work in trunk.
I think that the default region created when using a vector as input for
georeference should always be the default n=1 s=0 e=1 w=0 res=1 region
(i.e. the same that is created when creating a location without
determining a default region). One could argue that the user would like to
have a default region with the extents of the vector used for creating the
location, but as there is no way to determine a sensible resolution, the
risk is high that you get an arbitrarily large region with a resolution of
1, i.e. a very large number of pixels. Or we would have to decide on a
reasonable default number of pixels and adjust the region accordingly. But
I think that having an obviously non-sense region is better as it forces
the user to explicitly set the region.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3414#comment:4>
