[GRASS-dev] GRASS-GIS GUI failed to start
Anna Petrášová
kratochanna at gmail.com
Wed Sep 6 20:05:55 PDT 2017
could you by any chance install wxPython 3 from packages
(python-wxgtk3.0)? I think that should help.
On Wed, Sep 6, 2017 at 4:24 AM, Tung Nguyen <tungkttv at gmail.com> wrote:
> Thank you very much Anna!
> I finally managed to compile the snapshot version you posted.
> While compiling, I had this error
> Errors in:
> /home/Downloads/grass-6.4_2017/gui/wxpython
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Mon Sep 4 16:52:36 PDT 2017
> make: *** [default] Error 1
> LinuxMint17 ~/Downloads/grass-6.4_2017 $ cd ./gui/wxpython/
> LinuxMint17 ~/Downloads/grass-6.4_2017/gui/wxpython $ make
> After running make in gui/wxpython. The GRASS was successfully compiled.
> However the error still remained.
> GRASS 6.4.6svn (default):~/Downloads/grass-6.4_2017 > Traceback (most recent
> call last):
> File "/usr/local/grass-6.4.6svn/etc/wxpython/wxgui.py", line 34, in
> <module>
> from lmgr.frame import GMFrame
> File "/usr/local/grass-6.4.6svn/etc/wxpython/lmgr/frame.py", line 46, in
> <module>
> from lmgr.layertree import LayerTree, LMIcons
> File "/usr/local/grass-6.4.6svn/etc/wxpython/lmgr/layertree.py", line 37,
> in <module>
> from mapdisp.frame import MapFrame
> File "/usr/local/grass-6.4.6svn/etc/wxpython/mapdisp/frame.py", line 52,
> in <module>
> from wxplot.profile import ProfileFrame
> File "/usr/local/grass-6.4.6svn/etc/wxpython/wxplot/profile.py", line 28,
> in <module>
> import wx.lib.plot as plot
> File
> "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/lib/plot.py", line
> 132, in <module>
> raise ImportError, "Numeric,numarray or NumPy not found. \n" + msg
> ImportError: Numeric,numarray or NumPy not found.
> This module requires the Numeric/numarray or NumPy module,
> which could not be imported. It probably is not installed
> (it's not part of the standard Python distribution). See the
> Numeric Python site (http://numpy.scipy.org) for information on
> downloading source or binaries.
> These are the configs that I used
> CFLAGS="-g -Wall -O2" LDFLAGS="-s" ./configure \
> --enable-64bit \
> --with-libs=/usr/lib64 \
> --with-cxx \
> --with-freetype=yes \
> --with-freetype-includes=/usr/include/freetype2 \
> --with-postgres=no \
> --with-sqlite=yes \
> --enable-largefile=yes \
> --with-tcltk-includes=/usr/include/tcl8.6 \
> --with-opengl-libs=/usr/include/GL \
> --with-readline \
> --with-python=yes \
> --with-wxwidgets \
> --with-cairo \
> GRASS is now configured for:
> Source directory: /home/Downloads/grass-6.4_2017
> Build directory: /home/Downloads/grass-6.4_2017
> Installation directory: ${prefix}/grass-6.4.6svn
> Startup script in directory: ${exec_prefix}/bin
> C compiler: gcc -g -Wall -O2
> C++ compiler: c++ -g -O2
> Building shared libraries: yes
> 64bit support: yes
> OpenGL platform: X11
> MacOSX application: no
> MacOSX architectures:
> MacOSX SDK:
> Tcl/Tk NVIZ: yes
> BLAS support: no
> C++ support: yes
> Cairo support: yes
> DWG support: no
> FFMPEG support: no
> FFTW support: yes
> FreeType support: yes
> GDAL support: yes
> GEOS support: no
> GLw support: no
> LAPACK support: no
> Large File support (LFS): yes
> Motif support: no
> MySQL support: no
> NLS support: no
> ODBC support: no
> OGR support: yes
> OpenGL support: yes
> PNG support: yes
> PostgreSQL support: no
> Python support: yes
> Readline support: yes
> SQLite support: yes
> Tcl/Tk support: yes
> wxWidgets support: yes
> TIFF support: yes
> X11 support: yes
> I attached the full log of the compilation in case you want to look further
> into it
> Best regards,
> -- Tung
> On Wed, Aug 30, 2017 at 12:14 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> Is this version from packages? There has been some fixes, so maybe if
>> you could download and compile the latest version:
>> https://grass.osgeo.org/grass64/source/snapshot/
>> On Wed, Aug 30, 2017 at 11:23 AM, Tung Nguyen <tungkttv at gmail.com> wrote:
>> > Hi Vero,
>> > Thanks for the suggestion! I'd love to however some of the tools we're
>> > using
>> > are only compatible with GRASS-GIS 6.4
>> > Best regards,
>> > -- Tung
>> > On Tue, Aug 29, 2017 at 10:55 PM, Veronica Andreo <veroandreo at gmail.com>
>> > wrote:
>> >> Hello Tung,
>> >> Have you considered moving to GRASS 7.2? The last update of GRASS 6.4
>> >> series (6.4.4) was released one year ago and won't receive further bug
>> >> fixing.
>> >> I would highly recommend to move to grass 7
>> >> Best,
>> >> Vero
>> >> El 30 ago. 2017 12:28 a.m., "Tung Nguyen" <tungkttv at gmail.com>
>> >> escribió:
>> >>> Hello GRASS dev,
>> >>> I'm using GRASS-GIS v6.4.3 on Linux Mint 17.3 Rosa but couldn't get
>> >>> the
>> >>> GUI to start. I have tried all solutions I could find to no avail.
>> >>> What I
>> >>> have tried so far:
>> >>> - Uninstall & reinstall numpy (numpy-1.13.1)
>> >>> - Uninstall (purge) and reinstall python-wxversion, python-wxgtk2.8
>> >>> then
>> >>> grass-core, grass-dev & grass-gui
>> >>> - Error message:
>> >>> Welcome to GRASS 6.4.3 (2013)
>> >>> GRASS homepage: http://grass.osgeo.org/
>> >>> This version running thru: Bash Shell (/bin/bash)
>> >>> Help is available with the command: g.manual -i
>> >>> See the licence terms with: g.version -c
>> >>> If required, restart the GUI with: g.gui wxpython
>> >>> When ready to quit enter: exit
>> >>> [Raster MASK present]
>> >>> GRASS 6.4.3 (default):~ > Traceback (most recent call last):
>> >>> File "/usr/lib/grass64/etc/wxpython/wxgui.py", line 34, in <module>
>> >>> File "/usr/lib/grass64/etc/wxpython/lmgr/frame.py", line 46, in
>> >>> <module>
>> >>> File "/usr/lib/grass64/etc/wxpython/lmgr/layertree.py", line 37, in
>> >>> <module>
>> >>> File "/usr/lib/grass64/etc/wxpython/mapdisp/frame.py", line 52, in
>> >>> <module>
>> >>> File "/usr/lib/grass64/etc/wxpython/wxplot/profile.py", line 23, in
>> >>> <module>
>> >>> File
>> >>> line
>> >>> 132, in <module>
>> >>> the
>> >>> information
>> >>> on
>> >>> - Machine info:
>> >>> $ python --version
>> >>> Python 2.7.6
>> >>> $ inxi -Fxz
>> >>> System: Kernel: 4.4.0-28-generic x86_64 (64 bit gcc: 4.8.4)
>> >>> Desktop: Cinnamon 2.8.8 (Gtk 3.10.8) Distro: Linux Mint
>> >>> 17.3
>> >>> Rosa
>> >>> Graphics: Card: NVIDIA GM107GL [Quadro K620] bus-ID: 01:00.0
>> >>> Display Server: X.Org 1.17.1 driver: nvidia Resolution:
>> >>> 1920x1080 at 60.0hz, 1920x1080 at 60.0hz
>> >>> GLX Renderer: Quadro K620/PCIe/SSE2 GLX Version: 4.5.0
>> >>> NVIDIA
>> >>> 375.39 Direct Rendering: Yes
>> >>> Any suggestion would be appreciated. Thanks!
>> >>> -- Tung
>> >>> _______________________________________________
>> >>> grass-dev mailing list
>> >>> grass-dev at lists.osgeo.org
>> >>> https://lists.osgeo.org/mailman/listinfo/grass-dev
>> > Thanks!
>> > -- Tung
