[GRASS-dev] [GRASS GIS] #3414: v.import: ERROR: Invalid e-w resolution field: 0 when importing EU_LAEA point into Sinusoidal location
trac at osgeo.org
Thu Sep 7 06:30:10 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Projections/Datums | Version: svn-trunk
Resolution: | Keywords: v.import
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
I just attached a diff which I think should work for not attempting to
create a region based on vector extent. The region will simply be n=1 s=0
e=1 w=0 res=1.
I don't have time for much testing, so if others could, this would be
good. Not sure though that this is secure enough to introduce now into the
7.2.2 release. Probably should be noted under known bugs and backported to
release72 after the 7.2.2 release.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3414#comment:9>
