[GRASS-dev] [GRASS GIS] #3414: v.import: ERROR: Invalid e-w resolution field: 0 when importing EU_LAEA point into Sinusoidal location
trac at osgeo.org
Thu Sep 7 12:44:36 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Projections/Datums | Version: svn-trunk
Resolution: | Keywords: v.import
CPU: Unspecified | Platform: Linux
Comment (by neteler):
Replying to [comment:10 mmetz]:
> For v.in.ogr, some more changes are needed, see attached patch
no_vector_default_region_2.diff (the patch also solves some TODOs).
I get a compilation error:
[mneteler at oboe v.in.ogr ]$ make
gcc -O2 -march=native -std=gnu99 -fexceptions -fstack-protector -m64
-fdiagnostics-color -I/home/mneteler/software/grass73/dist.x86_64-pc-
linux-gnu/include -I/home/mneteler/software/grass73/dist.x86_64-pc-linux-
gnu/include -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\"
-I/usr/include/gdal -I/home/mneteler/software/grass73/dist.x86_64-pc-
gnu/include -DRELDIR=\"vector/v.in.ogr\" -o OBJ.x86_64-pc-linux-gnu/main.o
-c main.c
main.c: In function ‘main’:
main.c:886:35: error: ‘have_ogr_extents’ undeclared (first use in this
function); did you mean ‘have_ogr_extent’?
if (flag.no_clean->answer || !have_ogr_extents) {
have_ogr_extent
main.c:886:35: note: each undeclared identifier is reported only once for
each function it appears in
make: *** [../../include/Make/Compile.make:32: OBJ.x86_64-pc-linux-
gnu/main.o] Error 1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3414#comment:12>
