[GRASS-dev] [GRASS GIS] #3367: g.gui.animation: animated GIF export generates corrupted GIF files
trac at osgeo.org
Tue Sep 12 10:05:08 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.2.2
Component: wxGUI | Version: svn-releasebranch72
Resolution: | Keywords: g.gui.animation
CPU: x86-64 | Platform: Linux
Comment (by annakrat):
Replying to [comment:17 martinl]:
> Replying to [comment:16 veroandreo]:
> > Tested here having python2-pillow-3.4.2-1. Now, it works, but as you
say the GIF doesn't look so good in terms of definition of the images.
They look noisy, as when you increase ISO in the camera.
> I can confirm it. I have `python-pil 4.2.1-1`. See attachment:noisy.gif
created by
> import os
> from PIL import Image
> from grass.imaging import writeGif
> color_path = os.path.join(os.environ['GISBASE'], "docs", "html",
"colortables")
> pil_images = [Image.open(os.path.join(color_path, c)) for c in
os.listdir(color_path)]
> writeGif('/tmp/test.gif', pil_images, duration=0.2, repeat=True)
Could you test r71485? I used quantize function and it seems better.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3367#comment:20>
