[GRASS-dev] API to read latitude and longitude of vector.
Helmut Kudrnovsky hellik at web.de
Thu Sep 14 10:37:09 PDT 2017
CM Reddy wrote
> Hi All,
> We are new to Grass GIS and it's implementation. We have downloaded and
> compiled the Grass 7.2 version and trying to add new modules.
> We had already imported a vector map using v.in.ogr command. Imported
> map has nodes or points (four nodes) . We would like to read the
> latitude and longitude of those points from map programmatically. In
> case, any program or command is already available, it would be helpful
> for us.
> We would like to know the API's to be used to read the above information.
and for pygrass, have a look at:
https://grass.osgeo.org/grass73/manuals/libpython/pygrass_vector.html#geometry-classes
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
