[GRASS-dev] [GRASS GIS] #2461: GRASS 7: i.ortho.photo suite completion
trac at osgeo.org
Sat Sep 16 10:02:14 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone: 7.4.0
Component: Default | Version: unspecified
Resolution: | Keywords: i.ortho.photo, wxGUI
CPU: Unspecified | Platform: All
Comment (by neteler):
For the record (from private communication):
svn log --search ychemin -l 500 > ~/Desktop/iorthomodule_commits.txt
* r71069 fixed typo
* r71068 Replaced i.rectify with i.ortho.rectify
* r71065 some more adaptation
* r71064 first working version of the module
* r71063 modifying to support i.ortho.transform requirements
* r70990 updated group.control_points structure with z1 & z2 for
i.ortho.transform adaptation
* r70886 Added more meaningful comments
* r70885 Added more meaningful comment
* r70883 Added connection from group elevation file (set by i.ortho.elev)
to the GCP selection system, z value collected automatically on click in
target map
* r70858 Some more comments
* r70857 Added g.gui.iimage2target first shot, GUI is mostly done,
algorithm connection not working
* r70856 Added g.gui.iimage2target first shot, GUI is mostly done,
* r70855 Added g.gui.iimage2target first shot, GUI is mostly done,
* r70854 More information can be added to the ELEVATION file, bug fixing
* r70853 More information can be added to the ELEVATION file
* r70851 clarifying for users
* r70850 Modified to incorporate g.gui.iphoto2target
* r70744 Added error catching on reading elevation paramter file
* r70743 Module adds output file to the group for use in the next
i.ortho.photo module
* r70705 Added Apriori to standard deviation inputs names
* r70552 Added g.gui.iphoto2image, part of i.ortho.photo suite
* r70543 Added option to run g.gui.iphoto2image
* r70541 Added exception check for presence of group to allow creation by
i.group
* r70540 Made group required=no to use menu item i.group to create one
* r70538 Added default order value = 1
* r70482 Added i.ortho.photo to Makefile
* r70481 Added a menu to i.ortho.photo process
* r70479 improved Warning description
* r70372 Added i.ortho.target
* r70371 bug fix i.ortho.init input key names
* r70104 added transform
Ticket URL: <https://trac.osgeo.org/grass/ticket/2461#comment:4>
