[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Tue Sep 19 06:14:43 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:35 glynn]:
> Replying to [comment:33 mlennert]:
> > Replying to [comment:32 glynn]:
> > > The functions in grass.script should **never** return unicode. That
module reads the contents of files (which are sequences of bytes) and the
output from processes (again, sequences of bytes).
> > Is this true for translated module messages as well ?
> Yes. Anything which originates as a byte string (e.g. output from
commands, contents of files) should be kept as a byte string. Anything
which (for whatever reason) originates as a unicode string should be
encoded at the earliest opportunity.
Thanks for the explanations, Glynn. However, I'm really a bit lost in this
whole discussion. One example: I always thought that unicode was an
abstract representation, but that in practice a unicode string was always
encoded in some encoding, with Python 3 using UTF-8 by default. Or does
Python 3 really store the actual unicode code points ?
And what would it take for our C code to be converted to unicode ?
I think we need two things to go further on this:
* Write up (or link to) a clear explanation of the unicode issues in
Python, in the specific context of GRASS GIS with links between Python and
C code, so that we make sure we have a common understanding.
* Make it one of our priorities, probably better after the 7.4 release, to
sort things out in a coherent and clearly documented manner (including
best practice guide to developers), in order to avoid this issue bothering
us for years to come.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:36>
