[GRASS-dev] ERROR grass addon v/r.surf.nnbathy using a lat/lon location
Roberto Marzocchi roberto.marzocchi at gmail.com
Tue Apr 3 03:50:44 PDT 2018
Thanks Helmut. I have corrected the script.
Now it works also from GUI
R
2018-03-29 17:48 GMT+02:00 Helmut Kudrnovsky <hellik a web.de>:
> >Removing the mapset from input name (ztd_temp a meteo --> >ztd_temp) the
> module works correctly. I do not know how to solve >this problem. Perhaps
> it
> has an easy solution for you.
> Just have a look into GRASS scripts, e.g.
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/
> vector/v.habitat.dem/v.habitat.dem.py#L125
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev a lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180403/b7c06014/attachment.html>
