[GRASS-dev] r.in.gdal -r and r.import extent=region not working properly?
Veronica Andreo veroandreo at gmail.com
Tue Apr 17 00:15:24 PDT 2018
Dear Markus,
Thanks much for such a quick fix!!! Awesome! :)
Cheers,
Vero
2018-04-16 11:32 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
> On Sun, Apr 15, 2018 at 10:49 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> > On Sun, Apr 15, 2018 at 9:46 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> > > On Sun, Apr 15, 2018 at 8:48 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > >> Hi devs,
> > >> I just found something odd. I have a CHIRPS tif for Africa [0], but I
> would
> > >> only need to import Ghana, so I used r.in.gdal -r. However when I
> visualize
> > >> the data, most of it is nodata, while the full map of Africa has data
> all
> > >> over the continent. Then, I tried also with r.import extent=region.
> Same
> > >> result. The only thing providing what I expected to be the right
> result (a
> > >> subset from the full map) is importing the whole map and then using
> > >> r.mapcalc to clip (i need the space in my hard disk)
> > trying harder I can reproduce the issue (of course not NULL related).
> > So, I have no clue right now why it behaves differently.
> fixed in trunk r72620 and relbr74 r72621. That was a rather serious bug in
> r.in.gdal -r, therefore IMHO a new GRASS 7.4 release should go out asap.
> Markus M
> > markusN
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180417/d510d039/attachment.html>
